Map, map, whose got the map?
Old Jul 28, 2013 | 10:26 PM
Allen Riggs's Avatar
Allen Riggs
Default Map, map, whose got the map?
I have an 09 883 with duke intake and short shots. I am running a PCV with the canned map for this set up from dynojet. The problem is, they created this map for the short shots with the stock baffles. I am running the quiet baffles.
Vance and Hines maps for the fuel pack has 3 maps for the short shots: no baffles, stock baffles, and quiet baffles.
This tells me that there must be a needed adjustment for each setup.
I called Dynojet and they DO NOT have a map for the quiet baffles. Short of taking my bike to a tuner (I will after 1250 conversion) I am stuck with a not so accurate map.
Has anybody out there with 883 and short shots been able to find a map for the quiet baffles? If so, where? I bought my PCV from DynoJet so fuelmoto is not an option for me.
Thanks in advance.
Allen
Old Jul 28, 2013 | 10:30 PM
Tank27949's Avatar
Tank27949
Good luck getting maps. I had to hassle dynojet for a map which still doesn't resolve all my issues.
Old Jul 28, 2013 | 10:40 PM
Allen Riggs
I am toying with the idea of throwing my stock baffles back in until I can find the right map. At least this way it will be tuned correctly.
Allen
Old Jul 28, 2013 | 10:50 PM
vheflin's Avatar
vheflin
A good tune is the way to go. Forget about the canned maps. JMO but what do I know.
Old Jul 28, 2013 | 10:55 PM
Tank27949's Avatar
Tank27949
I don't have the option. i bought mine like this. i would like to put 2-1 on mine or maybe some screamin eagle pipes.
Old Jul 29, 2013 | 03:57 AM
DrewBone's Avatar
DrewBone
From: In the foothills of southwestern NC - US of A
Allen, herein lies just one of the advantages of the Power Vision tuner over the PC[III,V]; it's ability to autotune would have your problem resolved in the time it took you to perform a couple of 30 minute rides.
I'd venture to say that the PCV MAP is "close" and I can't imagine there being a markedly noticeable difference in tune between baffles...at least nothing harmfull can be done. But remember, after all, all "canned" MAP's are merely in the ballpark, as there are differences in all engines, intakes, exhausts, fuels, along with atmospheric/elevation conditions that make it virtually impossible to make a sewing machine running engine with every possible mod combination across the globe, soooooooooooo unless you're going with a tuner that provides an autotune feature or shell out the dough for a dyno session and a couple hours of qualified tech time, you're always going to be just "in the ballpark." 'Tis the way it is.
Yet from all the reading I've done here of those running ie., XiED's, the phrases "in the ballpark" and "good enough" seem to be mutually accepted around here. But what's impressive is that good enough isn't good enough for you! I hope you find a proper solution, but unfortunately, that may mean a trip to an indy for a dyno tune to satisfy your requirements and mind. Best wishes.
=8^)
Old Jul 29, 2013 | 12:02 PM
shopewell's Avatar
shopewell
=8^)
You can upgrade your pcv to an autotune as well. If your bike isn't popping and running super lean I wouldn't think there is a huge adjustment between the two baffles.
Surfcitydude
The Dyno Room
Jun 7, 2016 06:50 AM
Iron6677
Aug 17, 2015 03:58 PM
parts eeter
Apr 23, 2014 02:52 PM
dtone72rss
Apr 26, 2012 04:10 PM
Kdavid
Fuel Moto / Jackpot Mufflers
Apr 9, 2010 09:25 AM
