Starting problems
Old Oct 8, 2013 | 01:14 AM
chiro22's Avatar
chiro22
6th Gear
Default Starting problems
I picked up a used 2002 883 and recently there's been some issues with starting the bike. The battery is about a year old, and every few weeks, I go to turn it on and the electronics don't even come on. I ride every day as a commuter and feel like this is odd. I've hooked the battery up to a trickle charger and even when it says, "Charge complete" I turn the key and still no electronics. I'm thinking of replacing the battery, maybe it's a faulty cell, but maybe I'm missing something.
Any ideas
Old Oct 8, 2013 | 03:32 AM
Karate Dave's Avatar
Karate Dave
Red face
Could be any number of reasons for these symptons. Faulty connections are often the cause. Check the engine earth strap (ground wire) for clean and tight connection, and also check for water penetration on the ignition switch. If there is a problem with the wiring, then a new battery won't cure it. Hope you find the gremlin in your system.
skinman13
Sep 6, 2016 10:43 AM
bleachdriver
Oct 20, 2015 04:43 PM
mlrailguy
Aug 16, 2015 06:49 PM
MayhemMike
Feb 18, 2009 09:33 AM
wolfprint
Nov 22, 2007 12:57 PM
