The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
No Device: cylinder variances in a(any brand) tuner.
Old 01-10-2019, 11:43 AM
FREDStr33tbob's Avatar
FREDStr33tbob
FREDStr33tbob is offline
Default cylinder variances in a(any brand) tuner.
OK. I have a pumped up 103. I am tuning with a PC5 and an autotune setup(WHILE SAVING FOT A TTS)
My question is this,
In your tunes, that you either had someone tune(dyno) or self tuned with TTS, AUTOTUNE, whatever, in the same colum, same row in the fuel tables after you have set the AFR you want the bike to achieve, do you find huge differences between the cylinders.
If so are you comfortable with this? I have swapped the o2 sensors after a good cleaning and recalibration and it seems to make no difference in the cell adjustments. What could cause so much variation in the fuel tables?
now its not like its EXTREMELY drastic. however some are running a positive and some are running a negative number. EXPERINECE WANTED>
Old 01-10-2019, 02:03 PM
FLTRI17's Avatar
FLTRI17
FLTRI17 is offline
Only one bit of info missing...how does your bike run? Response? Smoothness? Fuel mileage?
The power commander only adds or subtracts % fuel from the existing ECM calibration so, depending on the mods and exhaust system, the numbers in the cells only represent what it took to get from base calibration to target AFRs you set.
Bob
FREDStr33tbob (01-10-2019)
Old 01-10-2019, 02:16 PM
FREDStr33tbob
Bob
The bike runs amazing. LOL Am working two different tunes... mileage and a power/fun tune. Everything is else is good too, response is there.. Smoothness is there... fuel mileage is hit and miss depending on how i ride. but its ballpark. its not like im not happy, im just asking if i should completely trust it when one cell on Cylinder 1 is -32 and the came cell on cylinder 2 is 45(i didnt see this until after the OP, thats pretty drastic change). The plugs are a good color. and not too lean and not to rich.... howerver the rear is a little leaner than the front bassed on plugs...
Old 01-10-2019, 04:17 PM
FLTRI17's Avatar
FLTRI17
FLTRI17 is offline
Trust results when they produce a great running bike. It is not uncommon to see big differences when recalibrating for different exhaust systems and cam timing compared to previous combinations.
Bob
Old 01-11-2019, 05:16 AM
Slingshot383's Avatar
Slingshot383
Slingshot383 is offline
It has to do with heat, the rear cylinder just naturally hotter than the front cylinder and needs a little more fuel to make for equal power output.
Las Vegas Jim (02-23-2019)
Old 01-11-2019, 07:54 AM
FREDStr33tbob
yeah some of the differences in a tuner are not naturally that way. I understand this and see it in some of the cells. however this is like way off of the 2-5% more.
Old 01-11-2019, 08:22 AM
jbarr1's Avatar
jbarr1
jbarr1 is offline
I feel it has way more to do with the uneven firing pulses that are inherent in a 45 degree engine than just a heat issue.
It is quite normal to have vastly different maps for front and rear cylinders and it’s exacerbated by inefficient exhaust and cam choices.
FREDStr33tbob (01-14-2019)
Old 01-12-2019, 11:06 AM
FLTRI17's Avatar
FLTRI17
FLTRI17 is offline
Originally Posted by FREDStr33tbob
...however this is like way off of the 2-5% more.
Not sure how or why you are into 2-5%?
Maybe you are referring to auto tuning where you look for 2-5% change and call it good?
Bob
Old 01-12-2019, 04:58 PM
marcodarq's Avatar
marcodarq
marcodarq is offline
i agree with jbarr1, not abnormal to see those types of differences and i think it has to do with the pusle and the shared intake runners.
m
Old 01-13-2019, 08:08 AM
hrdtail78's Avatar
hrdtail78
hrdtail78 is offline
All of the above and I will add injector tolerance variation, and pipe design/ a wobble fire engine.
Big Dave
The Dyno Room
06-13-2017 07:13 PM
ncracer86
11-06-2013 01:03 PM
joey883
02-10-2013 09:53 AM
scasey
04-05-2010 04:42 PM
DHart
10-01-2009 10:22 AM
Quick Reply: No Device: cylinder variances in a(any brand) tuner.
