Closed loop fuel management system
Old Nov 2, 2013 | 08:34 PM
ncracer86's Avatar
ncracer86
Default Closed loop fuel management system
Has anyone used this type? RC Components makes one. $400.00 and you can have one. They claim you dont have to map anything, no downloads, or dyno tuning using this. Im not familiar with these and wondering if they give you more power than other types or what happens here? You can add intakes, exhaust, etc without worrying about your fuel/air set-up. Anyone have any experience with these? I would have posted on the "Fuel/Intake/Exhaust" page, but it only shows about 5 threads for me. Although it says 18,000+, so I dont think thats right.
Here's a link for RC Components, hopefully it works. http://rccomponents.com/rcxhaust/pro...-celerator.htm
Thanks!
Old Nov 2, 2013 | 08:37 PM
'05Train's Avatar
'05Train
Your bike, assuming it's newer than 2007, is already closed-loop. Don't bother with anything other than a flash tuner (Powervision or TTS).
Old Nov 2, 2013 | 08:39 PM
ncracer86's Avatar
ncracer86
Yeah, I ride a '13 RG. I'd like to do some engine mods for some more power so I was curious about this.
Old Nov 3, 2013 | 07:23 AM
flhxs103's Avatar
flhxs103
What's the difference between the two'that makes PV better?
What's the difference between down loading maps and these closed loops?
Old Nov 3, 2013 | 07:54 AM
Sam2010's Avatar
Sam2010
Pv and tts both are good take you pick for your own reasons based on your own home work.
Old Nov 3, 2013 | 08:03 AM
Pine Tree's Avatar
Pine Tree
MODERATOR
If you're asking whether the PV or TTS is better, I think many will tell you it's personal preference.
I'm not sure what you're trying to compare.
Closed loop is simply the ECM's components providing enough feedback so the ECM can make certain adjustments. The same ECM can be set to use the input from its various components (closed loop) or set to ignore the feedback (open loop).
There are advantages to using either...one needs to simply understand the differences, what's gained, and what's given up.
Old Nov 3, 2013 | 08:42 AM
bsnilloc's Avatar
bsnilloc
Here is my review and experience with the plug and play COBRA FI2000 Power Pro tuner which is a "closed loop" tuner as you describe but does not change the map of the ECM.
https://www.hdforums.com/forum/touri...ence-dyno.html
Maybe that will shed some light.
Goodluck!
Old Nov 3, 2013 | 09:09 AM
btsom's Avatar
btsom
If you have a stock machine (no reprogramming or add on tuners) with O2 sensors, you have a closed loop system. The after market tuners typically are less expensive than either paying for a reflash at the dealer of buying your own SERT (Screaming Eagle Race Turner) and doing it yourself. The least expensive add ons put resistors (I believe) between the O2 sensors and the ECM to, in effect, lie to the ECM getting it to slightly enrich the mixture in closed loop operation.
Closed loop allows the computer to adjust for changes in conditions. Cold air is more dense than warm air, the computer can adjust for that. In the mountains, the air is less dense than at sea level and the computer can adjust for that. The tuners which disable closed loop remove the computer's ability to make those fine adjustments and sort of simulate having a carburetor. A standard carburetor can not adjust for temperature or altitude. In one of the steps toward modern fuel injection systems, cars had electrically controlled carburetors which were capable of making real time adjustments through computer control. They were only a 3 to 5 year intermediate step and the ones I had were rather trouble prone. I don't believe any motorcycles ever used that system.
Old Nov 3, 2013 | 09:32 AM
gipper's Avatar
gipper
The OP's post seems a little on the disingenuous side....
Old Nov 3, 2013 | 10:03 AM
$tonecold's Avatar
$tonecold
Yeah, I kind of thought that myself. "$400 and you can have one" sounds like an advertisement. I have known of people who used this system and it is OK if you are just doing pipes and air cleaner. For more than that it didn't work so well.
From Direct Cycle Parts you can have a Power Vision for $420. Then you have the ability to adjust for almost anything and build as far as you like. You can also download a map that is good for ac and exhaust. You can auto-tune with the stock O2 sensors or add the Pro Auto-tune with wide band O2 sensors. In my opinion (I am using one) they are superior to any other system I have tried. (Thunder-Max, PCV, EMS, Daytona TwinTech) All the other systems worked, just not as well as the Power Vision.
Did that sound like an advertisement?
