Closed loop fuel management system
Old Nov 4, 2013 | 04:25 PM
flhxs103's Avatar
flhxs103
I have asome questions on the pv-2 power Vision. I orderd it...
They said to start with the map that goes with-- High Flow Air Cleaner, Rinehart True Duals #14T103a02405.
I'm putting on V&H Dresser Duals w/ Rinehardt 4" slip on's.
Does that sound right?
Will I end up still needing a Dino in the end?
Old Nov 4, 2013 | 04:33 PM
1Canuck's Avatar
1Canuck
They recommended the closest map to what you have. Every setup, even the same setup will show some differences due to altitude, temp, fuel etc. follow instructions for data runs which will make necessary adjustments to the VE table for a more accurate air to fuel ratio. then re flash and do it again until the changes are within % they suggest as it will never be the same exact number after each run, usually changes within 5% are enough. you will not need a dyno tune, and this is subjective at best, a dyno tune could make it even better so that is your decision to find out.
Old Nov 4, 2013 | 04:43 PM
flhxs103's Avatar
flhxs103
Thanks, I get it now.
Old Nov 4, 2013 | 05:00 PM
Ultra103's Avatar
Ultra103
I have the RC Components X-Celerator on my 2012 Limited. It has performed flawlessly for two years.
I can't say that a different tuner and a dyno tune wouldn't net a few more horsepower, but it's not race performance I'm looking for. The bike runs nice and cool and EITMS doesn't kick in unless it's blistering out and I'm idling for a long time. No detonation, no hesitation (it takes the TBW 'lag' out).
That's all that matters to me.
Old Nov 6, 2013 | 01:03 PM
DirectCycleParts.com's Avatar
Sponsor
Default Dynojet Power Vision PV-2
Yea the PV-2 works great on the 2014 touring models.
There are only 8 maps out right now from Dynojet for the 2014s, but it seems they will cover most of the general set ups out there (most exhaust brands/configurations & high flow air cleaner)
All 2013 touring pipes and air cleaners will fit the 2014 touring models. Pick out what you like and go with the power vision.
Even on the earlier models, the PV is still a great unit. We have a PV-1 on our 05 CVO with cams, pipes, etc, and I would not use anything else!
If you need any help with these, we offer free support on them. If you do not want to stay on hold with dynojet trying to figure it out, you can call us and we can help you get into the best map config for your application.
Also, like they said, the PowerVision is only $419.95, and we also offer free support with them. =D
rnrobert
General Topics/Tech Tips
May 14, 2018 07:24 AM
joey883
Feb 10, 2013 09:53 AM
Sticky4
Feb 20, 2012 06:16 AM
2007fxdc
Aug 18, 2008 11:50 AM
doug garrison
Exhaust System Topics
Jan 26, 2008 06:22 PM
