The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
DYNOJET: Pv ?
Old Jun 12, 2017 | 08:47 PM
Big Dave's Avatar
Big Dave
Default Pv ?
When you go on to dynojets website and go to the tunes section , you put in your info and are given a choice of tunes - usually economy or power
So if you load one of these tunes and then run an auto tune session ( I understand theres no such thing )
My question is it shouldn't make any difference which tune you start with you should end up in the same spot if it is adjusting to your bike and riding style
So am i missing something ? - I have run 4 different maps and then with each map i ran 4 auto tune sessions comparing the final results they are very close to the same
No issues just curious what others have found
Dave
Old Jun 12, 2017 | 10:45 PM
IKnowNot's Avatar
IKnowNot
I believe they have tunes for economy, performance, and different octane fuels for stock, and possibly for other stage 1 builds.
As far as I know, the differences are with the fuel and spark tables.
Although the spark changes will affect the VE tables slightly, the VE tables, which the Auto-Tune sessions adjust, should still be close.
The fuel table should not affect the VE tables at all. Your AT session will set the entire fuel table to a single value while auto-tuning. Those fuel tables will be used when you are out of auto-tune.
Old Jun 13, 2017 | 02:25 PM
hrdtail78's Avatar
hrdtail78
Can you tell a difference between the cals. I'd have to assume the economy cal is great on fuel mileage, as the power cal should have more felt power.
I just set up one cal. I can get economy and power out of the same calibration because the AFR table allows me to do this. I break the same AFR table down to cruise, power, idle, accel, and decel.
Old Jun 13, 2017 | 05:46 PM
FLTRI17's Avatar
FLTRI17
Right on Jason. This is the only way, in my opinion, to tune a bike.
Best power at high load, best economy at cruise and low load areas.
Bob
Old Jun 13, 2017 | 07:13 PM
Big Dave's Avatar
Big Dave
This sounds ideal but you guys are way ahead of my home skills , I have found running the power cal then letting it adapt to that seems to make a very nice running bike and still gets good gas milage mid 40's mpg on a heavy bike that runs strong is all i need
Dave
themizz
Apr 18, 2014 01:54 AM
60wt
Aug 4, 2011 01:40 PM
fuelmoto
Fuel Moto / Jackpot Mufflers
46
Jun 8, 2011 01:00 PM
fuelmoto
Nov 12, 2010 02:51 PM
09StreetGlider
Feb 17, 2009 10:58 PM
