stock or aftermarket head pipe?
Old 09-20-2014, 07:25 AM
JAFLHTC's Avatar
JAFLHTC
JAFLHTC is offline
Default stock or aftermarket head pipe?
I have a 09 FLHTC with the stock headpipe and might do a cam change and looking for opinions on going with a S&S or Rinehart headpipe and didnt know if its worth it or not, mostly ride 2-4k range and most of the time 2 up. thanks
Old 09-20-2014, 08:27 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
If your headpipe has no cat, I'd go with that.
( most don't but CA spec bikes do end up in other States- even sold new on the floor, but that is mostly at Dealers which border CA)
the stock header will support over 100HP. another header pipe may provide only modest gains if any at all ( and you'd need one with the larger 18mm o2 bungs as on your 09- the 10+ are smaller).
my focus is function/cost over looks and trends.
If you afterward feel that your cam swap isn;t paying off ( expect about 10 HP- the choice of cam type will determine where in the rpm range that power shows itself)- you could add a header.
Most riders these days are buying headers have the 2010+ catalytic models and want a catless header
mike
Old 09-20-2014, 08:58 AM
fireman9170's Avatar
fireman9170
fireman9170 is offline
stock is fine
Old 09-20-2014, 02:36 PM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
I was surprised how much difference in performance and heat the Fullsac header made over the stock '09 non-cat header. Well worth it!
Old 09-20-2014, 03:22 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
Originally Posted by 0ldhippie
...how much difference ....!
Post some numbers or dyno sheets and a list of mods- Thanks
Mike
Old 09-20-2014, 05:29 PM
0ldhippie's Avatar
0ldhippie
Did not redyno header change. Mods are in garage.
Old 09-20-2014, 05:38 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
I think your 09 is the last of the catless headers, so I see no real reason to change the header. Plus your 09 has the 18mm O2 sensors. All good. I'd just focus on air cleaner, cams, mufflers, and tune. Might want to change out the lifters while you are doing the cam job just for longevity insurance. Check out Gaterman lifters. Remember to change the inner cam bearings to Koyo Torringtons.
Old 09-20-2014, 06:26 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
garage doesn;t show up for all users.
some "features" ( and ads) depend on the browser, OS, java scripting etc.
So good results on your butt dyno?
Thanks, Mike
Old 09-22-2014, 06:49 AM
JAFLHTC's Avatar
JAFLHTC
JAFLHTC is offline
Thanks for the input all
riderboy1961
Exhaust System Topics
04-10-2014 11:50 AM
flattracker60
07-06-2011 07:16 AM
Vivid Glide 103
05-19-2011 07:18 AM
fireguy5
01-06-2011 12:02 PM
al baehr
09-03-2010 02:27 PM
Quick Reply: stock or aftermarket head pipe?
