Retifier plug mismatch
Old Oct 9, 2014 | 06:44 PM
grieker's Avatar
grieker
2nd Gear
Default Retifier plug mismatch
Just dropped a 2006 engine into my 2004 ultra. Rectifier on the 2006 has a round three wire connector. The plug on the existing rectifier has a flat two wire connector.
Help!
Is there a "converter" plug out there somewhere? How can I rectify (sorry for the pun) this problem?
Thanks
George
Old Oct 9, 2014 | 08:03 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
with a wiring diagram and a universal connector, solder, and heat shrink tubing?
Old Oct 9, 2014 | 08:50 PM
mkguitar's Avatar
mkguitar
get an '06 style rectifier to match your stator.
mike
Old Oct 9, 2014 | 09:04 PM
grieker's Avatar
grieker
2nd Gear
Thought about that, for about a second... Three wires to two? Which three?
Old Oct 9, 2014 | 09:48 PM
Toofat's Avatar
Toofat
The problem is that the 2006 is a three phase stator, reason for the three wires coming off the stator. The 2004 is a two phase stator, reason it only has two wires. Why don't you just replace the 2006 stator with the 2004 stator that's in the motor you took out. If you do update to the 2006 regulator, you'll have to also purchase the wires&plug(part#74115-06) that go from the regulator to the battery. The reason being the 2004 battery wire is built onto the regulator and the 2006 battery wire plugs into the regulator.
Old Oct 10, 2014 | 07:29 AM
grieker's Avatar
grieker
2nd Gear
Thank you very much. I have tried to figure out how to get that friggen plug to the stator out of the block... Perplexing to those who have never done it.
Just looked. Stator exit from the crank is very different between the 2004 and 2006
Daddywags
Electrical/Lighting/Alarm
Sep 30, 2018 09:09 AM
Daddywags
Sep 29, 2018 11:39 AM
OLD 96
Mar 13, 2018 06:00 PM
kingjoey5000
Jun 14, 2013 01:40 PM
bg3075
Aug 14, 2011 03:52 PM
