fuel injector plug
Old Sep 30, 2018 | 08:42 AM
Daddywags's Avatar
Daddywags
Default fuel injector plug
Well, wires broke off at injector plug. Putting on new plug and wires up the harness. Does it matter which wire i solder on to plug, positive negative, wires broke off so I can';t tell which wire goes to the plug connector greenyellow or white either side of plug connector? Intuition tells me it would not matter. Thank you.
Old Sep 30, 2018 | 09:09 AM
ultra_classic's Avatar
ultra_classic
It shouldn't matter as it is a two wire solenoid, but you could check the other injector plug removed, and with the key on it would have power 12v on side, the ECM grounds the other to pulse or trigger the injector on time.
Daddywags
Sep 29, 2018 11:39 AM
GBHummer125
Jan 10, 2015 09:48 PM
kingjoey5000
Jun 14, 2013 01:40 PM
bg3075
Aug 14, 2011 03:52 PM
mississippiboy
Jan 21, 2009 10:59 AM
