Adding a second GPS
Old Nov 9, 2014 | 06:25 AM
DK's Limited's Avatar
DK's Limited
Default Adding a second GPS
I like the rally riding events and I have come to realize that adding a second GPS could prove to be very helpful, so I was wondering if anyone knows of a mount to place the GPS on the right side of the fairing. Id like it to look like it was meant to be there, I have the first unit mounted with the road tech mount on the left side, and it works well, I plan to put my phone in the middle, (Iron Aces mount on order) so that leaves the right side. Any options out there?
Old Nov 9, 2014 | 06:38 AM
glide2005's Avatar
glide2005
RAM is your best bet to look.
Old Nov 9, 2014 | 07:25 AM
sa53's Avatar
sa53
Why cant you use the same kind of mount on the right you used on the left?
Old Nov 9, 2014 | 07:28 AM
DK's Limited
@sa53..The mount on the left is designed to fit on the left, it has a part that is cut out to fit where the fairing is recessed. Hard to explain, I bought another mount with hopes that I can alter it to fit on the right side but I do not think it will work.
Old Nov 9, 2014 | 09:18 AM
sa53's Avatar
sa53
Oh, didn't know that. Maybe check Ram Mounts.
Good luck!!
Old Nov 9, 2014 | 07:35 PM
05UltraBob's Avatar
05UltraBob
Maybe see about getting one from overseas..... They drive on the other side of the road, so wouldn't the GPS be mounted on the opposite side?
Old Nov 9, 2014 | 08:11 PM
themensh's Avatar
themensh
Why do you need two GPS'?
Old Nov 9, 2014 | 08:14 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Old Nov 9, 2014 | 08:19 PM
SafetyMan's Avatar
SafetyMan
He REALLY doesn't want to get lost.
Old Nov 9, 2014 | 09:47 PM
Deucedog's Avatar
Deucedog
A GPS on the left
A phone in the middle
A GPS on the right.
When will you have time to actually look at the road?
Can't you just use your phone as a GPS?
