How to keep your engine running cooler
Nothing wrong with a SERT. It is an extremely capable tuning device when used by a competent tuner. A canned download is not getting a bike tuned. Getting it on a dyno where all parameters can be measured in real time is the only way to know the quality of the tune. Timing can have quite a bit to do with heat.
A Jagg 10 row oil cooler will bring oil temps down measurably. Exhaust design is still going to make a big difference in how much heat is being felt by the rider. Doesn't matter if it's Twin Cooled or not.
Zach
Zach
the sensor http://www.allelectronics.com/make-a...r-100-c/1.html the fanshttp://www.princessauto.com/en/detai...an/A-p8586604e alsohttps://www.westfloridacomponents.co...ny+SFF22C.html use a 12volt relay contacts to turn fans on and off via the 12volt relay coil ,which is controlled by the sensor on temp rise and fall
Tri glide 10
28
Oct 18, 2010 05:36 AM
GOSTAZ
Jan 19, 2007 07:18 PM
