The one the instructions refer to as 1, top left as your facing the bike from front. Rite behind the volts gauge.
They are calling that the "Interconnect connector". You might needs to chase the wires from the right side grip to make sure that is where it actually is located. that is not where mine is located.
Figure 3, in the instructions" show the wire that you need to find. It is labeled no 4.
I will check it out in the morning. I sure appreciate your help.
Found it! Came home from work last night and traced the wire from the right grip and there was the plug hidden way back under. Thanks Again
