2006 compensator question
Old Apr 5, 2015 | 08:06 AM
skydude426's Avatar
skydude426
Does a failed compensator or a loose compensator nut on a 2006 twin cam sound like rocks rolling around in the primary with an irregular pattern. Not a rhythmic pattern like a bad lifter or rocker arm might make? Thanks and Happy Easter
Old Apr 5, 2015 | 08:24 AM
steelerdude1's Avatar
steelerdude1
On my 06, when my comp nut came loose, I thought I broke a connecting rod, it sounded horrible. Scared the crap out of me, I thought my bike was dead.
Old Apr 5, 2015 | 06:59 PM
skydude426's Avatar
skydude426
Opened the primary today. Compensator nut came loose. Not sure if it had any lock tight on it. I'm also not sure if the springs are weak and the nut threads look a little mucked up so I'm replacing the whole assembly with one from a Drag Specialties just for safe measures. The threads on the crank shaft are clean as a whistle. That does make a terrible noise but once you've heard it you'll know it right away if you hear it again.
fftoddster
Mar 4, 2018 02:51 PM
waikiki
May 31, 2012 09:22 AM
mudpup
Jul 16, 2011 06:50 AM
steveh326
May 31, 2008 07:37 AM
Jmehaff
Nov 20, 2006 01:33 AM
