Sea Foam's Story
Marketing.
Real World; do not put this additive in your fuel if you are going in for emissions testing- you may fail.
After I did, SF advised to run 3 tanks of gas through the truck before re-testing...and I passed with same numbers as previous year.
Mike
Mike
I have used the stuff in my oil, gas tank, and throttle body on my car. Works fine. Heard miracle stories, heard horror stories...my thought is that the miracle stories are from people who were currently experiencing issues and the horror stories are from those that weren't but decided to use it anyway beyond just a stabilizer.
Received 2,525 Likes
Seafoam,well i have used it and it works ok but not beat at stabilizing fuel or cleaning carbs/injectors and carbon from combustion chambers either in the 4+ decades i have wrenching classic musle cars and bikes.
For stabilizing fuel sta-bils marine grade stable is their most concentrated version thats specifically formulated to handle the worst fuel storage cond which is i use & rec it.
I also like Startron too but dont have as much esp with it.
But as with any fuel stabilizer if its not properly applied its not near as effective if you add it to fuel thats alreadyx-amount of months old to begin with .
Best is to drain old fuel ,fully fill tank with fresh fuel ,add proper longs term storrage dose of fuel stabilized per mfg'd instructions,then start motor and ride bike for 10-15 mins to ensure the fresh treated fuel is introduced to the entire fuel system ,all carb circuts,injectors,etc & shut it down.
Then sit ready to be stored for up to 1 yr.
As for cleaning carb,injectors & carbon from intake valves,pistons & entire combustion chamber in general i found Chevrons Techron (stated as being " concentrated version" on front label) is a much more robust/concentrated cleaner then seafoam is .
Scott
Scott
I really like their products. I don't have statistical data but it helped my vehicles run better everytime. I'm not saying it was like new again! I'm saying it ran better, but that is cool out of just a can.
True story here: I used to bring my vehicle to a backyard mechanic. He was a pro, but worked out of his garage. He would always tell me if my vehicle ran rough to put a can of seafoam in the carb (following the procedure in the bottle) and in the gas tank. Then run it hard when are hitting the freeway ramps before bringing it in for an engine issues.
He called it mechanic in a bottle!
I had a transmission going bad on a Grand Wagoneer and I used seafoam transmission conditioner. It definitely helped it out. It lasted for many more thousands of miles until the axle snapped and I was three wheeling it over to the shoulder. After my buddy and I hopped out of the Wagoneer we noticed the axle grease caught on fire from the sparks from the brakes dragging on the pavement. We put it out easily but it was sad and funny at the same time. I guess all those burnouts were too much. Hey, I was young
Ive used it on my old bike a few times when I got bad gas. Worked great, used it a few times on other bikes that had a miss due to fuel problem worked great. Used it in a car with old gas in it worked great. Not saying its the fix-all cure-all but Ive used it a few times with good results. I only use it in my gas tho no where else.
Batman
Batman
