07 Flhx stalling
Old Jun 2, 2015 | 09:04 PM
cweiss's Avatar
cweiss
Default 07 Flhx stalling
Bike has been cutting off at times when coming to a stop. It acts like the idle stumbles and then shuts down. It has a pc3, s/e heavy breather and rinehart 2 into 1 pipe.
Any places to start would be appreciated
Old Jun 2, 2015 | 09:08 PM
dawg's Avatar
dawg
IAC stepper motor possibly. PC3 possibly. Any codes? Does it only do it when warm?
Old Jun 2, 2015 | 09:09 PM
pretz's Avatar
pretz
maybe this will help...
Old Jun 2, 2015 | 09:10 PM
cweiss's Avatar
cweiss
No codes and yes only when warm
Old Jun 2, 2015 | 09:18 PM
dawg's Avatar
dawg
Change the crank position sensor (CKP).
Old Jun 2, 2015 | 09:22 PM
dawg's Avatar
dawg
Here's a thread for you to read https://www.hdforums.com/forum/touri...codes-set.html
Old Jun 2, 2015 | 10:35 PM
wscott's Avatar
wscott
Assuming your 07 has EFI could possibly be:
* Dirty IAC & or dirty throttle plate.
* TPS going bad (if it has one)
* 02 sensor issue.
* Dirty Injectors ,( But if its running well/normal other then when you let off the throttle to idle then you would think it wasn't dirty injectors.)
BTW,is the ECU throwing any codes?
Good luck.
Scott
Old Jun 3, 2015 | 05:07 AM
Assegai's Avatar
Assegai
............... if the bike is occasionally difficult to start then I'd suspect the IAC.
Old Jun 3, 2015 | 07:31 AM
Deckman's Avatar
Deckman
I had the exact same problem. Tried cleaning the IAC valve numerous times and still had the same stalling. Then had the TPS (throttle position switch) changed and presto! No more stalling.
Old Jun 3, 2015 | 01:53 PM
nvsteve's Avatar
nvsteve
My 07 does the same thing. Cleaning the IAC fixes it every time.
