Quits while riding
Old Jun 8, 2015 | 11:21 PM
amunozroadking's Avatar
amunozroadking
6th Gear
Question Quits while riding
(2007 HD Roadking) Went on a ride, got low fuel, filled up, went about 2miles when I came to a stop. I proceeded but the bike began to sputter from one tail pipe and it felt like the other pipe had no power. I pulled to the side and it shut off by its self. Couple of guys came to help, we cleaned the carb and checked sparkplugs. The plugs looked good but we turned it over and there were no sparks on either plug. One pipe seemed to have a little fuel leaking. They said it could be a problem with the ignition. What should I do? What should I check?
Old Jun 9, 2015 | 06:29 PM
kojak's Avatar
kojak
Hmmm. 2007 road kings were fuel injected. What Carb were you cleaning?
Old Jun 9, 2015 | 07:49 PM
amunozroadking
6th Gear
I guess its an air intake valve?? its behind the air filter.
Old Jun 9, 2015 | 08:13 PM
amunozroadking
6th Gear
I guess its the air intake valve?? its behind the air filter.
Old Jun 10, 2015 | 05:23 PM
kojak's Avatar
kojak
Your problem could be few different things. First thing to check is to see if your bike is throwing any codes. It could be a bad ignition coil, a bad sensor etc).
Old Jun 10, 2015 | 07:28 PM
amunozroadking
6th Gear
Thumbs up
Thank you Kojak for your help. I really appreciate it. I happened to read other post that were similar and looked at my odometer to see if there were any codes given and didn't see any. Is that where I check for codes or do I need to connect it to something??
Old Jun 10, 2015 | 07:50 PM
lp's Avatar
lp
This will help.
http://www.fuelmotousa.com/p-29661-h...ble-codes.html
Old Jun 10, 2015 | 09:26 PM
sniperduce's Avatar
sniperduce
check the battery terminals they vibrate loose and I had these symptoms. Good luck
Old Jun 11, 2015 | 05:58 PM
amunozroadking
6th Gear
Originally Posted by lp
thank you very much!! awesome.
Old Jun 11, 2015 | 06:05 PM
amunozroadking
6th Gear
Thumbs up
I checked the terminals, positive was loose. However, after fully charging my battery and securing it, I still have the same problem of it not starting. No Spark.... I checked fuses and all good, next I'm going to look at any sensors or ignition coil. Thanks Sniperduce
