Cruise Control Problem
Old Jun 23, 2015 | 01:07 PM
ndnguyd's Avatar
ndnguyd
Originally Posted by Buelligan666
Ahhh, maybe specify rear brake switch? The most common is the one the OP said his dealer replaced. If the rear goes bad, does the brake light stay on all the time? Or does it not work at all? I would think the ecm "sees" the brake switch complete the circuit and cancel the cruise. Thusly the brake light would also be on all the time.
Well you would think since the dealer cant find the problem it just might be intermittent failure on the rear brake light switch witch is very possible. Had to replace that same switch right after the recall was done on it because the replacement was defective.
Old Jun 23, 2015 | 01:46 PM
Buelligan666's Avatar
Buelligan666
I thought the 2011 recall was for the taillight harness? When I bought my 11EGC that was the only dealer service that had been done to the bike other than they replaced the stator. I had my local hd dealer run the vin and called all the dealers that were on record for the vin. That's all they could tell me that was done to it. If there's a rear brake light switch recall, it must not apply to my vin. Maybe it applies to the OP's 2011 UC?
my2012ultra
Sep 17, 2022 03:35 PM
rlj50
General Topics/Tech Tips
Jul 12, 2015 06:25 PM
FrankP
Jun 26, 2012 10:06 PM
TexasVet
Aug 12, 2011 08:53 AM
maaiii
Feb 11, 2006 02:54 PM
