Cruise Control Problem
Old Jun 22, 2015 | 05:47 PM
rlj50's Avatar
rlj50
Default Cruise Control Problem
I have recently be experiencing problems with the cruise control on my 2011 Ultra Classic. Sometimes it engages, other times not. I've had the bike to my local HD dealer and they've run several diagnostic tests but have not determined the definite cause of this intermittent problem. They replaced the switch on the handlebars but it still hasn't solved the problem. Any suggestions on what might be causing this elusive situation? Thanks! RLJ50
Old Jun 22, 2015 | 07:36 PM
CGP93's Avatar
CGP93
From: Orig Surfers Paradise Australia, then Riyadh Saudi Arabia, Tokyo, Toronto, now So Cal
Do you have a PCV installed?
If so this may be the issue, search the Q&A section on the Dynojet website and it will tell you how to change a setting and fix the issue.
Old Jun 22, 2015 | 08:30 PM
ndnguyd's Avatar
ndnguyd
Brake light switch?????
Old Jun 22, 2015 | 11:13 PM
Buelligan666's Avatar
Buelligan666
Did you read anything other than the title of the thread?
Old Jun 23, 2015 | 06:54 AM
ndnguyd's Avatar
ndnguyd
Ahhh. matter of fact I did. There is one down by the swing arm that has been giving people problems.
Old Jun 23, 2015 | 06:59 AM
Pix's Avatar
Pix
Lots of cruise control problems associated with the brake lite switch.
Old Jun 23, 2015 | 08:34 AM
NDBadlands4-2's Avatar
NDBadlands4-2
It could also be the clutch switch. With the newer Rushmore bikes, that has popped up as an issue.
Old Jun 23, 2015 | 08:38 AM
dyna07custom's Avatar
dyna07custom
have you done anything to it recently Bars ,grips, etc
Old Jun 23, 2015 | 09:48 AM
corliss@bakerdrivetrain.com's Avatar
Or changed the gearing?
Old Jun 23, 2015 | 12:55 PM
Buelligan666
Ahhh, maybe specify rear brake switch? The most common is the one the OP said his dealer replaced. If the rear goes bad, does the brake light stay on all the time? Or does it not work at all? I would think the ecm "sees" the brake switch complete the circuit and cancel the cruise. Thusly the brake light would also be on all the time.
