2012 FLHTK cruise control problem
Old Oct 11, 2013 | 04:17 PM
my2012ultra's Avatar
my2012ultra
Stage III
Default 2012 FLHTK cruise control problem
I have a 2012 ultra limited that I am having cruise control issues. It will just shut off while going down the road AND even worse it will accelerate on its own!! The dealership says they can't make it happen so there is nothing they can do. Typical! Does anyone have any ideas for me? Thanks.
Old Oct 11, 2013 | 04:37 PM
Keithhu's Avatar
Keithhu
Does it throw codes? Mine cut out last year, turns out it was a bad switch, but I didnt experience the unrequested acceleration.
Old Oct 11, 2013 | 10:31 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
first guess would bet the accel decell switch.
Old Oct 12, 2013 | 10:33 AM
my2012ultra
Stage III
I don't know about the code. Isn't that something the dealership would check?
Old Oct 12, 2013 | 12:39 PM
Nute's Avatar
Nute
You assume too much. Look for the code yourself. Not all dealers are created equal.
Old Oct 12, 2013 | 01:25 PM
pastime's Avatar
pastime
Sounds like a short/pinched wire. I can see where it might not be repeatable for the dealer because it only happens to you infrequently. The problem the dealer has is they don't have a way to get paid to troubleshoot if they don't find anything if they're trying to do it as a warranty item. There are a lot of things to check and they could put several hours in and not find anything. You'd think they'd replace the switch as a start, though.
Old Oct 12, 2013 | 04:52 PM
jackhis's Avatar
jackhis
It appears you need to find a better dealer or arm yourself with service manuals (mechanical and electrical).
Old Oct 12, 2013 | 08:21 PM
Alter Kaker's Avatar
Alter Kaker
Senior Rider
Mine cut out on Cruise and the dealer had to search too - found it on the check ride after engine work. It was the brake switch, but I didn't have the random acceleration.
Good luck.
Old Oct 13, 2013 | 03:17 PM
my2012ultra
Stage III
Thanks for all the suggestion. Have it back at the shop. Going to the Key's for a week, so i told them to ride it till it shows up. Warranty over in March so I hope they find it before then.
Old Sep 17, 2022 | 03:32 PM
Maclimited's Avatar
Maclimited
Stage I
I have the same bike having the same issue with cruise control, did you find a fix?
