Ethanol Problems
Old Jul 23, 2015 | 10:47 AM
HotRod9mm's Avatar
HotRod9mm
Default Non-Ethanol
I try to stay away from Ethanol mostly because of the other side affects. I read an article that some
stations will run as much as 50%
When planing a trip I use google maps and Pure-Gas web site to mark stations that have non-ethanol,
then upload to my phone. I also have the Pure-Gas app on my phone.
Old Jul 23, 2015 | 10:52 AM
KCFLHRC's Avatar
KCFLHRC
That cant be true and would open up that gas station to severe legal issues.
Old Jul 23, 2015 | 10:54 AM
HotRod9mm's Avatar
HotRod9mm
Originally Posted by KCFLHRC
That cant be true
You would not think so but everything you read on the net must be true
Old Jul 23, 2015 | 11:01 AM
mrfikser's Avatar
mrfikser
hmmm, I was under the impression that alcohol had a higher octane rating than gas so that should mean less pinging..that said, where I live all we can get is the mixed gas and I never have a problem with pinging...
Old Jul 23, 2015 | 11:05 AM
Coastal CVO's Avatar
Coastal CVO
If you had taken a sample of the fuel for lab testing, you probably would have been pissed about the results.
Not uncommon to find low octane fuel in the high octane tanks.
Old Jul 23, 2015 | 12:15 PM
jt metal's Avatar
jt metal
Respectfully disagree...... Ethanol can't hold its octane value as long as regular gasoline. So 87 becomes 84 in a relatively short time span.
The other problem is in rural areas if 91 is available. It is so old, it's worse than 87.
I hate this! The whole thing sucks!
Truth....byof!!!! Bring your own fuel!
Old Jul 23, 2015 | 12:31 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Might find some improvement with a small tweak in your tune...
Old Jul 23, 2015 | 12:41 PM
dyna07custom's Avatar
dyna07custom
Originally Posted by DanRC
Ethanol has no effect on knocking, that is caused by low octane causing preignition under load. Up here in Minnesota, gasoline has 10% ethanol, unles you can find non-oxyginated fuel, and they are only allowed to be used in boats, atvs, motorcycles, and I believe in classic cars.
Same here and I have never had preignition
Old Jul 23, 2015 | 12:55 PM
J929626's Avatar
J929626
While Ethanol is a octane rating booster, it is a unstable one. If E10 or E15 needs to be used relatively soon after it has been blended or bad things can happen. Remember that Ethanol absorbs moisture.
If you have to by this stuff burn it don't store it.
Old Jul 23, 2015 | 02:35 PM
NoCoLoco's Avatar
NoCoLoco
I've never had any problems running E10 in any of my engines, big or small!
