shifter arm question
Old May 3, 2007 | 12:47 AM
rkc9999's Avatar
rkc9999
Default shifter arm question
Need a new shifter arm for my road king. I see that alot of them say they only fit soft tails or dynas. Do all the harleys have the same splined shaft?
Old May 3, 2007 | 11:44 AM
rkc9999's Avatar
rkc9999
Default RE: shifter arm question
bump
Old May 3, 2007 | 11:51 AM
gunrunner's Avatar
gunrunner
You can use others, I used a wide glide on my last bagger, most splines are the same on late models.
Old May 3, 2007 | 11:57 AM
HogBoy's Avatar
HogBoy
Can't imagine why you'd have a problem finding one--saw one in the HD shop that even said "Road King" on it, so they're out there.
Old May 3, 2007 | 12:01 PM
sleepneagle's Avatar
sleepneagle
To my knowledge, all the 5 speed shift levers are the same except 07. Just went through the same problem. You have to loosen the inner primary to replace the lever on the selector shaft. What you might try first, get a new allen bolt from HD, $1.00 make sure they give you the correct year. 07 is shorter for some reason. Remove the old bolt and install the new bolt and snug up. I use a wobble shaft extension for my allen socket. Once snug, give the extension/allen socket a good smack with a hammer, then tighten down as tight as you can. This 9 out of 10 times fixes the loose shift lever without all the extra work.
Old May 27, 2007 | 12:08 AM
rkc9999's Avatar
rkc9999
test
Old May 27, 2007 | 12:10 AM
rkc9999's Avatar
rkc9999
test
[IMG]local://upfiles/22857/D961EDDA813A4ED18D4A14C368831C9C.jpg[/IMG]
stoneybagger
Aug 20, 2022 07:35 PM
guesscrazy
Aug 3, 2016 10:24 AM
hardheaded
Jul 30, 2015 03:07 PM
6speed
Sep 26, 2008 02:28 PM
scottyp
Sep 14, 2007 07:45 PM
