help me identify this plug
Old Sep 5, 2015 | 07:32 PM
traildog's Avatar
traildog
Originally Posted by seniorsuperglideE8
Douche are for bags, Deutsch are for plugs. Just thought I'd help you out.
I was just checking to see if y'all were paying attention........
Old Sep 5, 2015 | 08:01 PM
14GuineaPig's Avatar
14GuineaPig
From the 2015 Road King Online Owner's Manual
See Accessory Connector (under left side cover). The accessory switch controls power to the accessory connector under the left side cover. See a Harley-Davidson dealer or www.harley-davidson.com for electrical accessories that may be purchased and installed on the motorcycle.
FLHR/FLHRC: See Nacelle Switches: FLHR/FLHRC. The accessory switch is on the right side of the nacelle.
Other models: See Fairing Cap Switches (typical). A panel for accessory switches is next to the ignition switch in the fairing cap. Switches can be added for installed accessories. The maximum load per switch is 2 amps.
  1. Auxiliary/fog lamp switch
  2. Accessory switch
I still don't know what the plug/connector is for.
Old Sep 5, 2015 | 08:55 PM
traildog's Avatar
traildog
So, I went out and removed the side panel and found 2 plugs with 2 different connectors.
I plugged my auxiliary power port http://www.harley-davidson.com/store...05-69200855--1 into the connector that fit, and my phone charger worked, but the switch on the nacelle had no effect.......
Old Sep 6, 2015 | 09:15 AM
GTK's Avatar
GTK
  2. Accessory switch
Thanks for posting that.It seems Moco decided to change switch locations after all these years.Maybe to convince potential buyers that the Road King has many new features.LoL
Old Sep 6, 2015 | 05:43 PM
Weavr99FLHT's Avatar
Weavr99FLHT
Default help me identify this plug
Your switch has no affect because the plug is multi-wired. On pre-14s the 4 wires were
Ground
On with ignition
On with ACC switch
On with brake.
The accessories have 2 wire, ground and one of the other 3. Depending on how the accessory is wired will determine when it has power. The 12 volt power port from HD uses the on with ignition.
I say "pre-14" because I've heard there is a slight difference but not 100% sure at the moment but similar enough.
lbkr22
Aug 19, 2021 03:29 PM
not yours
Electrical/Lighting/Alarm
Jan 3, 2019 02:01 AM
Bluraven
Apr 13, 2017 10:03 PM
Pops
May 27, 2011 08:23 PM
renorush
Apr 11, 2008 09:42 PM
