Piston oiler?
One of my oilers flows no matter the pressure, check valve bad. So it would be oiling at idle, would this be a problem? I took them out to make sure they weren't pluged after cam bearing failure. Putting new take off jugs & pistons in & want this motor to last a long time after done. I hear some have high oil pressure at idle so theirs would be oiling all the time I would think.
After installing old oilers found some S&S oilers from a almost local Indy. Great guy Phil @ TMM in Port Huron. Went to get some new take off pistons from him & he honed my new take cylinders ( I got eBay off that the pistons didn't match). He brought about needed S&S oilers, that the Harley ones are junk. I said ya I have one that flows all the time, do u have them. Awesome now better is right. Also picked up some Brad Penn oil & spectro primary. Nice shop II will be going back even though it's 60 miles away.
Yes there made not to flow @ low oil pressure, like 9psi. When flowing at low psi it takes away from everything else that needs it most & it floods the crank case.
Just got back from ride this bike likes to rev now. Sounds good & rocker lockers quited the top almost to nothing. I'm liking it!
I know for sure that they have a tiny little ball in them as one of those ***** went through my buddies oil pump and broke it.
Bowhunter61
Feb 2, 2017 06:07 AM
