Another engine knock thread
Old Nov 4, 2015 | 12:34 PM
vickers1's Avatar
vickers1
Mine started that after I changed the cams. Never did it before that. Mine sounds like it's coming from the right side. Quits after it warms up.
Old Nov 4, 2015 | 04:40 PM
kylebryan's Avatar
kylebryan
I went and picked up some conventional Harley 20w50 oil today at lunch. Going to swap it out and see if the noise is any better...
Old Nov 4, 2015 | 06:20 PM
Jon_S412's Avatar
Jon_S412
Ive got the same setup roughly in my bike and same noise going on. I'm curious to see if the oil change helps. Have not changed compensator yet though
Old Nov 4, 2015 | 06:31 PM
kylebryan's Avatar
kylebryan
Oil change didn't help... I've noticed I only get the noise between idle and 2200rpm. Higher rpm's the noise disappears.
Old Nov 4, 2015 | 07:03 PM
Jon_S412's Avatar
Jon_S412
How many miles on the motor now since its been built? Has the issue been there since day one of the build?
Old Nov 4, 2015 | 07:17 PM
kylebryan's Avatar
kylebryan
I've got about 12k on the build and it just started this noise after I got back from the sturgis rally.
Old Nov 4, 2015 | 07:23 PM
kylebryan's Avatar
kylebryan
Hypothetically if my primary chain was too lose would the noise stop when it came up to operating temperature like mine is doing? I need to take a video to see if anyone can ID this.
Old Nov 4, 2015 | 08:30 PM
Jon_S412's Avatar
Jon_S412
I'm sure a video would help. Crazy that it goes all the way up to 2200 in the rpm's. No difference in the performance of the bike?
Old Nov 5, 2015 | 07:24 AM
kylebryan's Avatar
kylebryan
Bike seems to be running fine, no performance issues.
Old Nov 5, 2015 | 02:12 PM
wscott's Avatar
wscott
Since your motor may have clearance issues & or wear that are made worse with syn oil that thins more making bottom end knock then then std dino then try this std dino oil in the motor thats a bit heavier grade which is specifically formulated for HD v-twins and try their primary oil formulated for HD's too.
Sometimes the compensator can knock too seeming to be the motor when it may not be the case which i also rec the spectro oil for the prim to change that at the same time too.
If you decide to try both these oils please note what oil pressure is with motor hot with the syn and then with motor hot when you switch to spectro's std dino 25w-60 motor oil formulated for HD's.
Also let us know if going to those 2 oil stopped the knocking noise and if it also quieted down the valvetrain if it had been noisy prior too.
scott
http://www.spectroshop.com/heavy-dut...60/prod_60.htm
Product Information
Heavy Duty
Spectro Heavy Duty Engine Oil is a superior motor lubricant designed specifically for use in American-made Harley® V-Twin engines. Crafted from superior petroleum stocks combined with the most advanced anti-wear, anti-carbon additive systems available, Spectro Heavy Duty extends component life, reduces wear, eliminates valve sticking. Meets all known OEM warranty requirements. Exceeds A.P.I. SF/SG – CD/CG - 4.
Be the first to review this product!
Price: $8.93
http://performanceoilstore.com/products.asp?cat=65&pg=4
Spectro Heavy Duty Primary Chaincase Oil 1-qt
Spectro Heavy Duty Primary Chaincase Oil 1-qt. This sheer stable petroleum is designed to withstand the punishment of high loads, and contains special polymers to provide exceptional clutch engagement and temperature stability. Meets full OEM requirements, and should be used according to manufacturers’ instructions. Formulated specifically for Harley® Sportster and Big Twin applications. Low drag, low friction loss SAE 85w viscosity helps eliminate clutch “drag” and slipping.
List Price: $12.04
Price: $7.95
