Gorilla handle bar clamp
A while back I changed out my stock bars to some aftermarket bars, if I pull a bit harder on the bars, they will slide down towards the tank. I have ordered a clamp that is supposed to eliminate the lose bar scenario. They have 3 set screws that are between the stock bolts holes that tighten the bars to the risers
Has anyone else out there changed out their bars and used this product or something similar. How did it work out for you. Were you, or are you happy with the new set up??
TIA
TIA
