DTT Availability
Old May 13, 2007 | 10:59 PM
musclehead's Avatar
musclehead
Default DTT Availability
My Drag dealer has been trying to order a DTT TCFI WEGO IID for several weeks the ship datehas beenrepeatedly pushed out, most recently until the second week of June. Delays may have something to do with the O2 sensors. Anyone know details on the delay? How about alternate sources that may have the DTT in stock? Thought I'd check with GMR, Rev Performance & Cateye Customs on Monday.
Old May 13, 2007 | 11:52 PM
PhilM's Avatar
PhilM
Default RE: DTT Availability
I would check with Bart @ Cateye (as you've mentioned), MandM Cycles, & CyborgCycles.com
Old May 13, 2007 | 11:55 PM
SpikeCT's Avatar
SpikeCT
The O2 sensor? its a stock item you can get at an auto parts store. It's a standard VW sensor....
Old May 14, 2007 | 12:56 AM
Bryan TTM's Avatar
Bryan TTM
if mine ****** with me one more time i'll have a damn carb lickety split and you can have my DTT with the HP 55
Old May 14, 2007 | 03:59 PM
usecotton's Avatar
usecotton
Bryan...sounds like you have about had it with DTT. What type of problems are you having?You seemed pleased when you first got it.I havent bitten the bullet yet but am inclined that way. Its always good to have honest feedback....
Andy
Old May 14, 2007 | 04:07 PM
Bryan TTM's Avatar
Bryan TTM
ok..its not the DTT...its the improper flanges on the HP Inc TB....Phil and Bernie found it this saturday....the TB wouldnt seal and had a bad intermitent air leak...the DTT saw the leak and added fuel, it thought i'd given it throttle bc the shaft was broke in half and that shaft turns the TPS....so all the parameters were in a constant uproar....now i got a new and improved HP TB but i'm sellin it...goinback to the stock 46 that came on my bike with the proper flanges for the R&R heads...a smaller TB should gimme more low end and since i finally found the culprit, it should do just fine
Old May 14, 2007 | 08:33 PM
SpikeCT's Avatar
SpikeCT
to have such a leak and DTT compensate for that large difference.... Thats an ATTA BOY for the DTT......
Old May 14, 2007 | 08:46 PM
Harleypaw's Avatar
Harleypaw
I'm having the same problems with the SE 50, and it's a bitch to change seals, I've had two flanges cracked already.
Old May 14, 2007 | 08:48 PM
Bryan TTM's Avatar
Bryan TTM
i have heard that as well....almost bought one....figg'rd i know the stock one will work and seal....tired of takin the TB off...it is a pain [:@]
ORIGINAL: Harleypaw
HardyHarHarley
May 18, 2023 04:14 PM
TXSailor
May 2, 2023 11:15 AM
rodney123456
Jun 30, 2011 07:21 PM
07flstc
Nov 23, 2007 03:10 PM
Hammer02
Mar 30, 2007 07:39 PM
