cable length
Old Apr 1, 2016 | 06:47 AM
stbobshadow's Avatar
stbobshadow
Default cable length
Looking to change to 14in apes on my 2012 street glide. How long does the clutch cable and brake lines need to be.
Old Apr 1, 2016 | 10:11 AM
RaceFace's Avatar
RaceFace
I went with 16" Carlini's, which are actually closer to 17's and I went +8" on all cables and brake lines and +12" on the electrical extensions. You can probably use that and knock off a couple of inches for shorter bars. Good luck!!
Old Apr 1, 2016 | 11:00 AM
decencyxdefied's Avatar
decencyxdefied
My 14s (Kst) which are measured at 14 used +8 or 70"
Old Apr 1, 2016 | 01:32 PM
stbobshadow
That's +8 on the brake line and 70in on the clutch cable correct
Old Apr 1, 2016 | 02:30 PM
SBates08's Avatar
SBates08
No sir. A +8 clutch cable is 70"'s.
Also +6 fir the brake line. +8 will give you a little more to work with.
Old Apr 1, 2016 | 03:17 PM
BB59's Avatar
BB59
I have installed WO 14" Apes on an 06 and an 08 RK and used +8 from Magnium Shielding for both the Clutch and Brake lines.
Be careful about using +6 on bikes with ABS as the mid lines are all the same length. The difference in cable length is taken up from the perches to the midline connection. I tried a +6 brake line on my 08 RK and it pulled the midline connection just enough that it showed where it came out of the Nacelle. Fortunately I only had to purchase one new section.
Again this was with Magnium Sheilding cables on a RK so I'm not sure this would apply to your Street Glide but it's something to think about. You want to have enough cable that the connection is hidden
If you go to their website they have all clutch and brake cable lengths listed including stock.
https://www.magnumshielding.com/inde...771&color_id=3
DonCMcC
2014-2024 Touring Models
Mar 24, 2015 08:40 PM
FYRE1UP
Jan 8, 2014 09:03 AM
SBRoadKing
Feb 17, 2013 05:40 PM
TheBagger
Nov 26, 2009 01:11 PM
05Fatty
Jun 11, 2009 07:12 AM
