Got my wild1 chubby installed and when i put the inner fairing on and line up the bolts i noticed the radio has gap between it a the fairing at the bottom due to the thicker bars.
I just finished my WO578 install. I had a gap between the switch shroud and inner fairing so I sanded the corners off the lower switch shroud with a die grinder. Fits like normal now.
Make sure you have the inner fairing mounted a little lower in the slots which will raise the inner fairing a quarter inch or so. I have the 1 1/4" chubbys with zero issues.
The slots that the hex cap screws go through to secure the inner fairing. The "slot" allows you to raise the inner fairing 1/2". This should help your stereo clear the bars.
Mine doesn't have slots, so i took my dremel tool to it with a drum sander fits perfect now.
