Re-installing inner fairing
Old Feb 9, 2014 | 08:39 PM
Puggy's Avatar
Puggy
Default Re-installing inner fairing
I had my inner fairing painted. I have it mounted and everything looks ok. I'm having an issue getting my radio back in. I've had to shave off the excess paint on the lip of the opening but still can't get it to slide all the way into the opening. Any suggestions? Also, the lower fairing is actually sitting on the ignition mount to the point that it has a slight upward bow in it right in the middle. Do I need to realign the inner fairing up just slightly?
Old Feb 9, 2014 | 08:44 PM
sanman4ever's Avatar
sanman4ever
Are you sliding the radio in from the back?
Old Feb 9, 2014 | 08:46 PM
Puggy's Avatar
Puggy
Yes...
Old Feb 9, 2014 | 08:50 PM
sanman4ever
Been a while since I did mine. A picture may help.
Old Feb 9, 2014 | 09:21 PM
Puggy's Avatar
Puggy
Any suggestions on how to post pictures from my Iphone. I searched and undoubtedly, the admins don't/won't allow access to this site through tapatalk.
Old Feb 9, 2014 | 09:52 PM
jlj6t's Avatar
jlj6t
I just did mine yesterday. Trick for me was pull the black fairing support bracket up and forward about 45 degs, and have the inner fairing generally in position but leaning towards the rear. Then as they were pushed into each other and down, the radio slid into place with no issues. I left the radio installed in the fairing bracket...not sure if you did the same or took yours out.
At any rate, I didn't have to do anything special to get 'em back together. And I didn't have any issues with the inner or fairing cap hitting anything it shouldn't. Not sure if any of that helps...probably not.
Old Feb 10, 2014 | 12:02 AM
14 FLHX's Avatar
14 FLHX
Pictures from iphone
Push the + next to the send
Then attach from photos
Click camera roll
Pick your pic
They will download
Then click new post upper left
Attached Thumbnails Re-installing inner fairing-image-2004174985.jpg   Re-installing inner fairing-image-2897297543.jpg
Old Feb 10, 2014 | 08:32 AM
Puggy's Avatar
Puggy
I'm thinking that the bottom of the radio cradle is hitting the clamp bolts underneath and keeping it from going into the slot straight. Make sense?
Attached Thumbnails Re-installing inner fairing-image-3006497114.jpg   Re-installing inner fairing-image-1500635905.jpg   Re-installing inner fairing-image-1966863816.jpg   Re-installing inner fairing-image-2423790378.jpg   Re-installing inner fairing-image-572437507.jpg
Old Feb 11, 2014 | 06:12 PM
Puggy's Avatar
Puggy
Anyone? Hello?
Old Feb 12, 2014 | 02:49 AM
HDSAE60's Avatar
HDSAE60
You tried to loosen the fairing bolts up and get it in?
