arc audio question
Old Apr 6, 2016 | 09:17 AM
harley7316's Avatar
harley7316
Default arc audio question
Hi was wondering on 125.2 mini i see almost everyone connect the power on wire to the spare wire on the headlight harness but wondering why you need it if you use the auto sense switch doesnt the mean when signal from speakers are sent from Head unit the amp turns on?Thx
Old Apr 6, 2016 | 10:15 AM
booch's Avatar
booch
check on the audio section in the tech forum, tons of info and help there.
Old Apr 6, 2016 | 11:21 AM
journeyman's Avatar
journeyman
When you say connect the power wire to the spare at the headlight, you know you still need to run a separate 30 amp supply for the power, right?
Old Apr 6, 2016 | 11:24 AM
harley7316's Avatar
harley7316
yes i mean the power on wire
Old Apr 6, 2016 | 11:26 AM
harley7316's Avatar
harley7316
you have + and - and a power on that goes to spare wire in head light thats what i am wondering why you need it if using out sense switch the amp should turn on when it get a signal from speakers
Old Apr 6, 2016 | 11:47 AM
rg_dave's Avatar
rg_dave
Switched power. Keeps the amp from draining your battery when the bike is off. Not sure about autosense but wouldn't take a chance.
Old Apr 6, 2016 | 11:59 AM
SBates08's Avatar
SBates08
Hook it up without it. If your HU sends enough volts it'll turn the amp on. If not use the remote wire and hook it to the spare wire on the headlight plug. It's not hard to figure out which one you need.
Old Apr 6, 2016 | 12:00 PM
Roadie13's Avatar
Roadie13
Hi level speaker inputs can be used with stock head unit, but low level RCA inputs are generally a better source, especially with aftermarket HU
Old Apr 6, 2016 | 12:24 PM
harley7316's Avatar
harley7316
Thx for the help
Old Apr 6, 2016 | 01:24 PM
skratch's Avatar
skratch
I read that in the arc amp install directions too. tried it. it didn't work.
