? for FP3 users
Old May 21, 2016 | 10:01 PM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
Default ? for FP3 users
Must the ecm have the stock flash to begin using the FP3 or will it work with a ecm that has a stage 1 flash?
Old May 21, 2016 | 10:10 PM
Jaystn62's Avatar
Jaystn62
Good question. I'm curious to know myself. I would assume it would still work though. It may just save your present map to reinstall later.
Old May 21, 2016 | 10:11 PM
Bradbodigon's Avatar
Bradbodigon
I would find out before you plug it into the bike and do anything because the FP3 marries to your vin # and you'll never be able to use it on another bike now return it once you take the plastic off the box it comes in
Old May 21, 2016 | 10:28 PM
tpcowfish's Avatar
tpcowfish
It will save whatever map that is already installed, and will flash the new map from Vance and Hines, then auto tune new map if you want to, yes it will work
Old May 22, 2016 | 07:48 AM
TcHunter's Avatar
TcHunter
Personally, I would have your dealer flash your bike back to stock.
You would would want the FP3 to have the stock settings to work off of and store into the memory, and there would be no chance of conflict between the two flashes.
Old May 22, 2016 | 08:24 AM
BigDawgQC's Avatar
BigDawgQC
^^This.
Don't worry about dealer flash. It will have no impact using the flash from FP3.
Old May 22, 2016 | 11:10 AM
dontdropit's Avatar
dontdropit
Other than going to the dealer is there any other way to find out if the ecm is has a stock flash?
Old May 22, 2016 | 12:34 PM
Jaystn62's Avatar
Jaystn62
Did the dealer do the stage 1 flash and how did they do it?
Old May 22, 2016 | 01:03 PM
dontdropit's Avatar
dontdropit
No I'm just curious, I know that some tuners will only work from a stock tune.
Old May 23, 2016 | 12:16 PM
CaptainKirk's Avatar
CaptainKirk
I started with the Stage I dealer flash. Installed the FP3, it created the baseline flash and I've reflashed it a couple of times. No worries.
