American Elite wet traction
Gotcha. I run a little less pressure in the rear, 35 psi or so and like it. I never inflate solely based on the mfr recommendations; I try to find what's comfortable for ME.
Try experimenting with pressures. Take it down to 35 psi in the rear (wont hurt a thing), and then go for a ride and feel the difference.
Good luck!
Good luck!
You got caught out in the rain, that is all! Do nothing until you have at least a couple of hundred miles on dry roads. All tyres come with a shiny surface as a result of the manufacturing process and until that is worn off will not give their best.
Got my new American Elites put on last week. Went out for a little ride this afternoon and got caught in the rain. Actually kinda glad because I wanted to see how the new tires would be on wet roads. It rained pretty hard through a twisty stretch of road and I took it easy because I'm never sure just how aggressive you can lean on a wet road. Bike handled fine, but I was far from pushing it. A little later on a nice straight stretch going up a hill at about 60 in 4th gear, I rolled on the throttle pretty hard, you know cause it's fun. Well the rear tire actually broke loose and the *** end got squirrelly. Let off and it settled down. Makes me wonder if I'm gonna have to baby these tires in the rain, or maybe just not whack the gas like a jackass.
What's everyone else's experience with these tires in the rain? How are the limits of leaning in the Twisties?
A couple of points on this, which you probably already know but if not maybe this will help.
All new tires are slick when they're new, almost like a coating on them and they can get a bit squirrelly on dry roads so wet I can imagine would only be worse. When you get a few miles on them, and maybe you did by later in the afternoon, they may be a bit better.
The other thing, how much standing water was on the road? I've had a rear tire "float" on me before wand it wasn't because it was worn out it was because I was moving along (probably too fast) and I went through a fairly deep bit of standing water. Best tires in the world will break loose in certain conditions.
I've had a few elites on my bikes and never had an issue, they work well in wet conditions and they wear great too!
I don't think you'll have any issues...... Unless you're doing 100 in a monsoon! Lol
I too just put the American elite on.
Although it was dry, I rolled on the throttle pretty hard and dump the clutch. There was lots of smoke coming out the rear tire and she was getting a little Squirrley too but traction was great.
I imagine it's a lot worse in the rain. LoL
Sticker tires are always slick in the beginning And need to break in.
