Advice....please
Old Aug 24, 2016 | 12:42 PM
0ldhippie's Avatar
0ldhippie
No surprise "auto tune" tunes lean but the tune shouldn't really change (go rich) at altitude if the o2 and map sensors are working correctly. Either way a proper Dyno tune should "fix" it.
Old Aug 24, 2016 | 01:00 PM
profp's Avatar
profp
I do an annual cross country through that area Georgia, Calif, DC, back). Bear in mind you have different gas mixtures between the southeast and the west.. and more availability of no ethanol gas too. Of course, the winds in Ok, Kansas, western Colorado all play heck with your gas mileage. I run a PCV with autotune and depend on it to compensate for elevation, temp, etc. Just saying
Old Aug 24, 2016 | 01:22 PM
smalls78's Avatar
smalls78
My gas mileage in Kansas was absolutely horrible. Highwinds and running at 85 to 90 mph. I was only getting about 110 miles to a tank.
Old Aug 24, 2016 | 01:23 PM
smalls78's Avatar
smalls78
Originally Posted by JMC22
Wouldn't the thinner air here in Colorado = less oxygen, thus if the bike was running lean when the OP left SC, when he got to Colorado where there is less oxygen at altitude = a proper mix, thus when going back to sea level with lower elevation = more oxygen be a lean mixture problem and make the bike run hotter and backfire?
They say the higher you go in elevation, the lower grade gas you really need due to lower oxygen levels...
Your explanation sounds pretty spot on. Actually, I think I should just move to Colorado.
Old Aug 28, 2016 | 09:00 PM
smalls78's Avatar
smalls78
This bike has such a noticeable difference today riding in comparison to CO. It's running very "harsh" it seems. I know FuelMoto can fix this and I'm gonna contact them. If more fuel needs to be added to mimic the rich sensation I had in CO from thin air and low oxygen, I don't see how this can't be adjusted with the PowerVision.
JBrock
Dec 8, 2017 11:32 AM
Toliverpeterson
2014-2024 Touring Models
Jul 24, 2016 12:44 PM
smalls78
Jun 21, 2016 08:24 PM
yandeltx
Sep 26, 2011 06:56 AM
only90s
Aug 8, 2008 09:18 PM
