Lowering Front End?
Mike,
I thought this out and through machining cut the fork tubes and sliders down 1 1/4", lowered the fender 1 1/4" onto the wheel, but kept the stock stroke. This machine costs around $550.00 and in this case used modified Racetech cartridge emulators & springs making up the shorter length with shorter spring pre-load spacers. There is nothing you are going to be able to do with the harsh ride of the 21" tire along with its inertia the larger diameter produces. All of the aforementioned internals can be modified to mount inside of the shorter fork. This is the HD lowering solution in a 2006~13 FLT:
The purpose of the OP's modification is cosmetic over ride quality. In all cases reduced ground clearance equates to reduced lean angle. This is how I did it for a customer:
I cut the fork tubes threaded end and re-machined everything 1 1/4" shorter.
I machined down (you will see later) the sliders so they are round to be able to mount inside the sof-jaws than made the fixture to fit for the horizontal milling machine.
After dry mock up assembly of the sliders & forks without fork springs to check measurements:
A trip to the chromers, install the Racetech internals (Note* I do not install the unit as per Racetech instructions), than add oil to control the air spring. The internals do not matter for visual impact. The Ohlins FKC-101 cartridge kit can be modified to install into these forks if anyone is actually interested in improved ride quality. The ride would be exactly the same as a FKC-101 (once re-valved) in a standard length fork as would be the lean angle because the bike still has the same ground clearance due to the 21" front wheel. Now add the fender lowering/drop brackets from e-Bay ($35.00/pr) The front wheel in this example is not a larger 21" but a 19" if memory serves me correctly.
Good luck with your modification.
http://www.arlenness.com/prodcat/Low3.asp
https://www.nativecustombaggers.com/...uspension.html
I used the Arlen Ness dampers along with the H-D lowering springs (shorter but stiffer) I already had in with about 1/2-5/8" spacer and higher oil level. It does ride stiffer but have no problem (so far) with the fender striking the driving light cross bar. When you lower the front end with a tall wheel there are few options available to keep the fender from hitting something, without going stiff and/or limiting travel. Beside raking the front end out.
