loctite for comp. bolt ?
Old 11-27-2016, 03:30 PM
hardheaded's Avatar
hardheaded
hardheaded is offline
Received 2,488 Likes on 1,544 Posts
Default loctite for comp. bolt ?
what loctite to use on compensator bolt, 262 or 271 ? i know the bolt comes with a red patch thread locker on it, but i always add alittle more.
Old 11-27-2016, 04:09 PM
FlamedFXR's Avatar
FlamedFXR
FlamedFXR is offline
Received 1,539 Likes on 655 Posts
Doesn't matter what you add, whats on there will do the job just fine.
Old 11-27-2016, 04:16 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
I use red
DO NOT use air impact tool on this.
If you need to get torque, you can use a bar on your torque wrench and stand on it...
Mike
Old 11-27-2016, 04:31 PM
rscott's Avatar
rscott
rscott is offline
just buy a 3/4 drive torque wrench they are inexpensive
Old 11-27-2016, 07:34 PM
hardheaded's Avatar
hardheaded
i have every size torque wrench i need . i was asking about the which loctite to use on the comp. bolt. i always used the 271 on the evo and shovel and even put some on the 12 twin cam when i had it apart. i've run out of the 271 and have a big bottle of the 262. i think the 271 is stronger than the 262. going to get into the primary of my 15 trike.
Old 11-28-2016, 04:33 AM
LQQK_OUT's Avatar
LQQK_OUT
LQQK_OUT is online now
Received 1,565 Likes on 1,083 Posts
Loctite 262 Threadlocker
Medium to High Strength / Red
A permanent threadlocker for fasteners up to 3/4" (20 mm) in diameter. High lubricity for easy assembly.
Excellent for preventing rust and corrosion in extreme chemical/environmental conditions.
Motorcycle Applications:
Engine:
Clutch Hand Nut
Crankcase Bolts
Drive Sprocket Retaining Nut
Transmission Sprocket Nut
Loctite 271 Threadlocker
High Strength / Red
Locks fasteners up to 1 1/2" (36 mm). Protects threads from rust and corrosion. Removable with heat and hand tools.
Engine:
Compensating Sprocket Nut
File Type: pdf
Old 11-28-2016, 08:56 AM
rscott's Avatar
rscott
rscott is offline
use the red my comment on torque wrench was because of using a pipe on wrench comment hardhead suits
Old 11-28-2016, 09:21 AM
voodoodrug's Avatar
voodoodrug
voodoodrug is offline
done the same thing,I am curios
F-ing Hostile
Air Suspensions
09-10-2012 01:52 PM
robvg
03-15-2012 01:25 PM
HOG_0308
07-18-2010 11:01 PM
HDF Tech
General Topics/Tech Tips
03-30-2009 12:17 PM
ScooterGuitar
05-16-2006 12:30 AM
Quick Reply: loctite for comp. bolt ?
