E3 plug failed
Old Jan 29, 2017 | 11:05 PM
bdtaylor1979's Avatar
bdtaylor1979
That sucks.
Old Jan 29, 2017 | 11:39 PM
103 sedona orange's Avatar
103 sedona orange
Originally Posted by cajun1957a
I had to pull the bike out of the garage today to move stuff around. Started up and ran it back in and suddenly it started missing on the rear cylinder. I pulled the rear plug and it was wet. Swapped it with the front and sure enough it was the spark plug. E3's with less than 2000 Km on them. Thing ill go back to stock plugs. The E3s seem to start the bike better but then again, there never was a starting issue with stock.
randy
Did you have problems with the OEM plugs? If so what problems?
Old Jan 30, 2017 | 06:10 AM
cajun1957a's Avatar
cajun1957a
No I never had issues with stock plugs. I decided to try the E3s. Some called it snake oil other swore by them. I try to keep an open mind about stuff so I tried them. You guys know all about that, Dyno vrs.......................well you know.
randy
Old Jan 30, 2017 | 06:53 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Smart Move IMO. The E3 is a gimmick anyway.
Old Jan 30, 2017 | 06:59 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
I remember the big ad blitz for "Rapid Fire" plugs a few years ago. I tried them in a stout small block chevy, no real difference in power, much shorter life, money thrown down the drain. Back to stock plugs. A friend tried plugs with 4 points, same results. Those were carbed engines, Holly 750 4 barrel spreadbore double pumpers, big fuel dumpers. HEI ignition systems, the works.
Today's fuel injection systems in conjunction with the ignition systems do a pretty good job doing what they do. I'm going to ride it, stock plugs and all.
I have already been down the plug road before.
Old Jan 30, 2017 | 01:19 PM
bigjames4xl's Avatar
bigjames4xl
Best spark plugs, stock and side gaped! Index them too if you want to be **** about it.
Old Jan 30, 2017 | 01:29 PM
Joe12RK's Avatar
Joe12RK
I had no issues at all with them. And it did start better. I'm an engineer and I am perceptive to every little noise, rattle, misfire etc etc on a motorcycle almost to the point of being obsessed...
Randy
please be honest, now that you have new stock plugs can you feel or hear the bike running better ? you may have felt an improvement with the E3s but it was probably old vs new plugs
Old Jan 30, 2017 | 03:33 PM
cajun1957a's Avatar
cajun1957a
I am being honest when I say the bike started better with E3s and even with brand new stock the E3s were still better. This is definitely a plug malfunction. With an ohm meter probe on one end and the other on the center electrode, the bad plug is all over the place compared to the plug that still works. But YES gentlemen, I will stay with stock sparks. An oh to be totally honest, my 1965 sportster kicker would NOT start cold with the three sets of stock plugs with any less than five to seven kicks. The splitfires plugs everyone laughs at, would fire that that XLH in two kicks cold every time. Some bikes like certain plugs, ask any old timer and they will tell you that.
randy
Rossi
Apr 12, 2016 04:47 PM
fiveola
Shovelhead
23
Dec 19, 2009 09:36 AM
mvent
Exhaust System Topics
Nov 17, 2007 03:05 PM
doakley2
Dec 12, 2006 12:54 PM
Paul G
Nov 2, 2006 09:20 PM
