Speedbleeder install: with original HD o-ring or not?
The Speedbleeder brake fluid nipple replacements do not come with an o-ring--but, the original HD nipple does have one. I have not seen any reference to installing this o-ring on the Speedbleeder. If you have experience with this I would like to know. Thank you.
I had the same issue.....here's a post I made at the time
nvm, found this in the service manual, maybe helpful to others :
When removing or replacing a bleeder valve in the rear
brake caliper or front banjo bleeder bolts, remove the oring from the bleeder valve groove or bore and discard.
The o-ring is required only for brake bleeding at the factory .
Although not sold separately , it may be present in certain
assemblies as currently sold. If care is not taken to remove
and discard the o-ring, it ma y become lodged in the caliper/banjo bleeder bolt bore during bleeder valve installation and prevent proper torquing or sealing
