Clutch spring
Old Apr 4, 2017 | 06:18 PM
Mykl Johnson's Avatar
Mykl Johnson
Stage I
Default Clutch spring
I saw a question about removal through the derby cover but didn't see how to actually remove the spring itself. 96 road king.
Help!
Old Apr 5, 2017 | 08:55 AM
grbrown's Avatar
grbrown
Hi from the UK and welcome to HDF. I don't know of any way to get to the spring to remove it, other than by removing the primary cover. To remove the spring involves using a bulky extractor tool, it's not something we can do with our fingers! This is the sort of job that justifies buying the factory service manual, which explains all.
Old Apr 5, 2017 | 10:08 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Pull the derby cover, remove the six bolts that are holding the clutch spring retainer onto the clutch assembly, and then just lift/pull it out. Easy Peasy!
Old Apr 5, 2017 | 10:40 AM
grbrown's Avatar
grbrown
Lightbulb
No bolts on a '96 clutch!
Old Apr 5, 2017 | 11:53 AM
todd-67's Avatar
todd-67
Like GR mentioned the older ones are different and you have to pull the outer primary cover off.
Born2cure
May 21, 2026 10:55 AM
timeout
Feb 18, 2012 10:42 AM
gli.der
Mar 29, 2009 11:12 AM
labfreak
Jun 29, 2008 06:30 PM
Segerfan
Jun 6, 2006 05:27 PM
