Codes pulled
Old May 31, 2017 | 05:50 PM
Atlantaclassic's Avatar
Atlantaclassic
Default Codes pulled
I pulled P0152 which is the rear O2 high, on S it pulled 61121 & 61122. The blinkers work fine but the only thing I see is the red key will occasionally stay lit and the rest of the time it blinks. I cleared the codes and ran it for a little while and rechecked codes but they did not come back. Do I need to replace the rear O2 anyway? The previous owner did put a new battery in the day I picked it up. Could that have caused the S codes?
Attached Thumbnails Codes pulled-20170531_162529.jpg   Codes pulled-20170531_173927.jpg   Codes pulled-20170531_174024.jpg
Old May 31, 2017 | 05:55 PM
dawg's Avatar
dawg
That would be b1121 and b1122 for codes
Old May 31, 2017 | 05:58 PM
dawg's Avatar
dawg
If they cleared and didn't return, they are historic. I wouldn't worry about it unless they keep coming back.
Old Jun 1, 2017 | 08:42 PM
Atlantaclassic
The b1121 and b1122 came back today. All the blinkers work fine do not sure what the problem is.
Old Jun 1, 2017 | 08:57 PM
dawg's Avatar
dawg
Are the turn signals self-cancelling as they are supposed to? You per chance don't have LED bulbs do you?
Old Jun 1, 2017 | 09:04 PM
Atlantaclassic
Yes they self cancel.. All the turn signals and brake lights are LED. previous owner had installed at HD. Back several years ago
Old Jun 1, 2017 | 09:24 PM
dawg's Avatar
dawg
Does it have a load equalizer? If not, that could be the reason.
Old Jun 1, 2017 | 09:53 PM
Atlantaclassic
They were on the bike when I bought it. I can pull the seat and see if one was installed.
Old Jun 3, 2017 | 10:01 AM
Atlantaclassic
Well P0152 code came back for the O2 sensor. Anyone have the part number for it. I googled but came up with different ones.
Old Jun 3, 2017 | 10:27 AM
dawg's Avatar
dawg
27719-07 is the HD number for the two 02 sensors on your scoot. FYI, that code doesn't necessarily mean you have a faulty 02 sensor. Riding conditions and whatnot can set that code. I've gotten that code a bunch of times, it doesn't set off my CEL.
