07 Roadking code P1353
Old Jun 25, 2017 | 06:08 AM
1cycledisciple's Avatar
1cycledisciple
Stage IV
Default 07 Roadking code P1353
While out cruz'n last week my 07 RK stopped firing on front cylinder ( tried screwdriver to ground and even touching screwdriver, nothing! Trailered home, Ran code check and got the P1353 / Front cylinder no combustion. Went ahead and ordered new coil/Wires got same result. HD Electrical Diagnostic Manuel has me hooking up a Breakout Box along with Harness Test Kit to the tune of about $800.00 if I buy both.Prior to towing to dealer wanted to see if anyone had this same issue.
Old Jun 25, 2017 | 06:14 AM
e6fmf's Avatar
e6fmf
Default No combustion,
I would look at plugs and wires.
Old Jun 25, 2017 | 08:14 AM
1cycledisciple
Stage IV
I did plug a spark tester between the wire and plug on the rear cylinder 1st, and it flashes while cranking. Then I moved it to the front, no flash and bike fires up on rear cylinder.
Old Jul 15, 2017 | 11:13 AM
1cycledisciple
Stage IV
**UPDATE** Found problem to be faulty Dynojet Power Commander 3 I installed with pipe/filter intake upgrade in 07. Bypassed this plugging stock harness directly back into ECM and front cylinder started firing again. ( No bad feelings toward Dynojet as it was 10 years old). Installed Vance/Hines FP3. Like it so far!
Old Jul 16, 2017 | 09:35 AM
14GuineaPig's Avatar
14GuineaPig
Glad you got it working & thanks for posting the fix.
1cycledisciple
Jun 25, 2017 05:45 AM
dpersson
Engine Mechanical Topics
Apr 14, 2017 09:30 PM
hkshooper
Exhaust System Topics
Jul 14, 2013 12:04 AM
2007heritage
Electrical/Lighting/Alarm
Feb 16, 2012 06:44 AM
normski
Mar 29, 2010 03:57 AM
