2000 fuel injected road king won't start
Old 08-13-2017, 07:06 PM
jacksellers's Avatar
jacksellers
jacksellers is offline
Stage I
Default 2000 fuel injected road king won't start
Bike sat a while, I drained tank and refilled with primium gas, everything looks the same i am getting spark and can hear fuel pump but will not fire unless i put fuel in cylinders directly ie: pull plugs, pour in a little gas. Bike cranks but will not fire. Any help is very much appreciated
Old 08-14-2017, 07:30 AM
Porky11's Avatar
Porky11
Porky11 is offline
Try pushing up on the fuel connector on the bottom of the tank and see if that works as this happened to my 2007 as the fitting gets worn a little and won't let fuel through if it is fuel injected.
Old 08-14-2017, 08:14 AM
ORradtech's Avatar
ORradtech
ORradtech is offline
If the bike sat without fuel stabilizer and you are getting fuel to the injector you may need to clean or replace the injectors.
Old 08-14-2017, 10:32 AM
im's Avatar
im
im is offline
We can not see or hear the bike.
The more details available the better the answer you might receive.
For now it would seem that:
You have a 2000 Road King
It is fuel injected
It has unknown miles
It has unknown history
It has unknown options like pipes,air box, fuel adder (example:like power-commander), handle bars etc.
Bike "sat a while" : was that a week , a month or 10 years?
When was the last time the bike functioned correctly?
When you you write "everything looks the same " what does that mean? did you remove the top plate on fuel tank to look inside the tank for debris?
You state: bike cranks and starts when fuel is placed inside the cylinders then based on the limited information available it reads fuel related.
It is possible that some debris are blocking the fuel sock on supply line in the tank or you have a problem at EXTERNAL fuel line connection to tank.
Is it possible that someone removed the fuel tank or disconnected the fuel lines that attach to tank for some kind of service?
Old 08-15-2017, 12:29 PM
carlgrover's Avatar
carlgrover
carlgrover is offline
Received 2,200 Likes on 1,275 Posts
I've got a fuel injected EVO that doesn't want to start after it's been sitting for several days or maybe a week. To get it running I just hold the throttle open a little and it roars to life. Not really sure what's going on with it but I think the throttle plate is sticking from sitting around. Day to day it starts right up.
carl
Old 08-15-2017, 01:08 PM
svarnster's Avatar
svarnster
svarnster is offline
I would start by checking fuel pressure
Old 08-15-2017, 07:33 PM
Veekness's Avatar
Veekness
Veekness is offline
Check fuel pressure first, thinking about possible pin holes in the in tank lines. If that checks out, spray Sea Foam in the throttle body while it's running for a little cleaning action.
fish425093
05-21-2021 09:40 AM
cwsharp
2014-2023 Touring Models
03-29-2019 02:08 PM
DrDave4
01-15-2013 08:51 PM
Stealth 03
Carburetor Related
01-07-2012 10:06 PM
tgarrett1
Road Trips
05-09-2007 12:54 AM
Quick Reply: 2000 fuel injected road king won't start
