Please help hesitate/missing
Old Sep 17, 2017 | 09:52 AM
kickstartfan's Avatar
kickstartfan
total miles on the motor?
Sorry if I missed it. Just another clue.
also, is it getting worse?
Old Sep 17, 2017 | 09:54 AM
Thekid338!'s Avatar
Thekid338!
5th Gear
About 34,000 and yes a little worse.
Old Sep 17, 2017 | 11:23 AM
sweet johnnie's Avatar
sweet johnnie
when mine starting acting up this year with 12 or 13k on it,i tried everything you have,no luck called a dealer and was adv'd to run ethanol cleaner thru it and change fuel filter....fixed mine.....
Old Sep 17, 2017 | 07:04 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I would think the Seafoam would have cleaned your injectors. Have you checked your front cylinder plug wire? Heard some problems with the insulation rubbing up against the tank and shorting out the spark.
Old Sep 18, 2017 | 08:40 AM
Thekid338!'s Avatar
Thekid338!
5th Gear
I did check wires both front and back to be safe.
Old Sep 18, 2017 | 08:43 AM
Thekid338!'s Avatar
Thekid338!
5th Gear
Originally Posted by bigdumbnoitall00
if u changed the tps i would have it calibrated.
Checked with dealer. No calibration on tps for 07 ultra
svarnster
Jul 26, 2016 05:18 PM
KiwiATC
Jul 4, 2016 07:02 AM
murphink
Oct 8, 2014 12:09 PM
JohnSWA
Jul 30, 2013 08:45 AM
craigdolson
Jul 21, 2011 09:53 PM
