biketronics
Old Jun 18, 2007 | 01:24 AM
southerlytide's Avatar
southerlytide
Default biketronics
I am planning on buying the biketonics retro radio pack i have a EGS what is the install like ? how long?,any problems,if any just a idea what Im in for. i want it with the ipod and xm too. any feed back will be appreciated
Old Jun 18, 2007 | 08:23 AM
jbhawley's Avatar
jbhawley
Default RE: biketronics
search this site for biketronics...i am sure you will get tons on info without us having to repeat ourselves.
Old Jun 18, 2007 | 12:10 PM
Harleypingman's Avatar
Harleypingman
I installed the biketronics interface unit and used Mike's mounting kit for the headunit. His instructions are very clear; no special tools are required.
If I hadn't already purchased the Sony GT510, speakers, HD speaker adapters, and fairing mounted antenna by the time I purchased the interface unit and mounting kit, I would have purchased the $499 package Mike offers that includes all of that stuff to begin with.
Before you begin installing everything on the bike, there are seven wires to splice from the interface unit to the Sony plug wires (2+ speaker, 2- speaker, ground, ignition and battery) that are color-coded--simple. Then remove the outer fairing; install speaker adapters; install speakers; remove plastic shell from hole in inner fairing where radio mounts; mount stereo headunit using mounting kit;connect the spliced wires to the appropriate speakers, ground, battery, and ignition sources; plug OEM Base Audio Connector into interface unit; connect antenna to headunit; and, plug Sonyplug into rear of headunit and you are good to go. Takes no more than two hours.
As jb said, do a search and you will find numerous threads on biketronics; some with pics.
Old Jun 19, 2007 | 12:58 AM
Spartan's Avatar
Spartan
Just received the retro radio package today.Read thru the instructions and it seems pretty simple. Plan on doing the install this week.
Old Jun 19, 2007 | 01:19 AM
capt42a's Avatar
capt42a
I used the Biketronics Retro Radio kit on my 06 FLHT/I and everything was plug and play, no wire splicing needed in my case. The connectors were already there for the radio and speakers and the handlebar controls work just like with a factory radio.
capt42a
ORIGINAL: Harleypingman
blackv03
Audio Systems
11
Mar 21, 2016 02:59 PM
jwk784
Audio Systems
Mar 15, 2013 01:12 PM
liquiddeputy
Apr 8, 2011 06:26 PM
Cyclemedic69
Apr 29, 2010 11:42 AM
so165
Sep 25, 2008 04:12 PM
