Fuel Filter?
Old Jun 4, 2018 | 08:13 AM
LostTexan1997's Avatar
LostTexan1997
Stage II
Default Fuel Filter?
Just bought a 1993 Heritage Softail - the bike had not run in 2 years. Drained tanks put in new fuel and replaced battery. Could get it started with starter fluid and then idles rough. Drove down the road then cuts off, can restart but only run short distance and does the same. Could the fuel filter cause this issue?
Old Jun 4, 2018 | 08:40 AM
merlin 2's Avatar
merlin 2
carb. rebuild is in needed .
Old Jun 4, 2018 | 10:32 AM
sbeast's Avatar
sbeast
start with the obvious, new air filter, fresh oil, and plugs. After that, pull the carb, rebuild and clean the hell out of it. if that doesnt help, try the fuel filter.
Old Jun 4, 2018 | 10:45 AM
bad tappets's Avatar
bad tappets
Could be bad gas from sitting. Drain tank, re fill with new gas; then go from there.
Old Jun 4, 2018 | 10:50 AM
LostTexan1997
Stage II
Thanks for the insights - gave that a shot first thing.
Old Jun 4, 2018 | 01:02 PM
JCBGlide's Avatar
JCBGlide
It is 25 yrs old.... If it still has the OEM Vacuum petcock, good chance the old vacuum operated diaphragm inside is Bad and/or the petcock filter is clogged too. They were POS' when new. I'd replace it anyway. May as well replace all the hoses as well plus do what the others are suggesting.
65camino
Apr 16, 2018 10:37 PM
Don Lampert
Jun 17, 2014 11:28 AM
petewood70
EVO
Aug 2, 2010 11:47 AM
kylant
May 14, 2007 01:21 PM
