Removing Oil Cooler
Old Jun 6, 2018 | 04:23 PM
woodthumb2's Avatar
woodthumb2
Default Removing Oil Cooler
i need to remove the factory oil cooler in my flhtk to get to my regulator... it is drivin me nuts... is this thing held with T45 torx bolts? is a torx a torx or does harley do something different here...? my indy want about 75 to replace this and im thinkin it should be straight forward once i get this cooler out....providing the regulator plug ins have a little slack ... preciate it
Old Jun 6, 2018 | 05:01 PM
Boomer1143's Avatar
Boomer1143
Yes, they are torx headed bolts. Remove the 2 bolts and the cooler will be able to move some. I believe the 2 nuts that hold the regulator down are 7/16th.
Old Jun 7, 2018 | 02:29 PM
Ragtop's Avatar
Ragtop
Make sure you use a quality torx bit, cheaper ones could damaged the fastener, not something you want to do!
Old Jun 7, 2018 | 06:38 PM
woodthumb2's Avatar
woodthumb2
yep.. thanks. ..got it.. it is a torx T45 by the way ..picked one up at homedepot.... husky..fit nice and tight and i was a little surprised how easy they moved...now on to the regulator
rider718
Sep 30, 2014 12:53 PM
mi2az
Aug 7, 2011 05:24 PM
homyakchik
Apr 23, 2009 08:57 PM
Softtail Bob
May 18, 2007 05:00 PM
ricks
Dec 29, 2006 01:57 PM
