Compression Release - Is this normal?
Old Jun 21, 2018 | 04:20 PM
criyi's Avatar
criyi
Default Compression Release - Is this normal?
I have a 2010 Street Glide with the 96 cu inch motor. Every time I ride, stop for a few minutes and restart (example:getting gas), The starter cranks for a rotation and stops to a loud halt. I'm assuming this is due to no compression release. Is it accurate to say it doesn't have a compression release and if so is this normal behavior? Is there any easy fix?
Old Jun 21, 2018 | 04:25 PM
clintox's Avatar
clintox
Are you always in neutral when you start the bike? If not, shifting to neutral before starting should fix the issue.
Old Jun 21, 2018 | 05:26 PM
K Melancon's Avatar
K Melancon
The 96 did not come with compression release and started with 103 from factory. Unless it was added afterwards
Old Jun 21, 2018 | 05:33 PM
Keithhu's Avatar
Keithhu
Sounds like a bad compensator to me.
Old Jun 21, 2018 | 05:34 PM
big- mike's Avatar
big- mike
Check your battery and or the connections but no the 96 did not have acr's your bike may be wired for them but that would require head work to add them
Old Jun 21, 2018 | 05:36 PM
Notgrownup's Avatar
Notgrownup
You could get 1 manual compression release on the rear cylinder, it helps . I had 1 on my 96 inch and it would make a huge difference on hot start.
Old Jun 21, 2018 | 05:42 PM
big- mike's Avatar
big- mike
I went with the s&s ez-start cams when I did my 103 upgrade
Old Jun 21, 2018 | 06:20 PM
criyi's Avatar
criyi
Usually not, I'll try it.
Old Jun 21, 2018 | 06:25 PM
criyi's Avatar
criyi
Thanks for your suggestion. I just watched a bad compensator video and it doesn't seem to be that. On hot startup it will turn the motor over once, clunk and stop turning. I have to let off the starter and try again for it to start.
Old Jun 21, 2018 | 06:26 PM
criyi's Avatar
criyi
I will check but it starts no problem every time, it's just that hot startup where it wants to do this.
