Oil Cooler
Old Jun 30, 2018 | 05:13 PM
Campy Roadie's Avatar
Campy Roadie
Originally Posted by CndUltra95
Not having had one the first 132000 miles of its life hasnt done no harm...
Save the money for gas.
Rob
Agreed.
No need to ask anyone for advice, you have all the evidence you need.
Old Jul 1, 2018 | 02:03 PM
wscott's Avatar
wscott
Originally Posted by itsmf
Are there any advantages to installing an oil cooler on a 2009 Ultra/with 132,000 miles. It also has a stage 2 103 kit.
YES THERE ARE BIG ADVANTAGES TO COOLING DOWN AN AIR COOLED HD IN SUMMER HEAT
I also have a stock 09 ultra (now 28k miles)that used to bake me in summer heat that would make it detonate,loose significant amount of pwr/trq,throttle response was mushy,oil pressure went to crap esp at idle(7-8psi @ idle & 32-35psi @ cruise),lifters/valve train & motor in general would make more noise etc.
I installed Wards cooling fans (like Love Jugs new smaller Mighty Mites?) along with a thermostatically controlled fan assisted oil cooler both at
the same time and wow what a diff that made right off the bat which were as follows:
* OIL TEMP IN SUMMER HEAT WAS REDUCED UP TO 50DEG F.
In summer heat oil temp used to hit 250-275 deg f in avg stop/go traffic & 235-245+ @ cruise.
Now in summer heat oil temp runs approx 225-235 deg f in avg stop/go traffic & 195-200deg f @ cruise in same summer riding cond.
* OIL PRESSURE @ IDLE WENT FROM 7-8 TO NOW 17-18PSI & OIL PRESSURE @ CRUISE WENT FROM 32-35PSI TO NOW 45-47PSI
IN SAME HEAT COND WITH SAME OIL.
* VALVE TRAIN/LIFTERS & MOTOR NOW REMAIN QUIET.
* NO MORE DETONATION
* MOST OF THE POWR/TRQ THE MOTOR USED TO LOOSE IN SUMMER IS NOW RETAINED.
* THROTTLE RESPONSE RETAINS IT'S CRISP FEELING TOO.
* HOT RESTARTS POST FUELING UP ARE QUICKER/EASIER WITH NO HESITATION BECAUSE MOTOR/BATTERY/STARTER
ARE NOT AS OVERHEATED/HEAT SOAKED.
* RIDERS ARE NOT HIT WITH AS MUCH EXTREME HEAT IN SUMMER CON WHICH REALLY MADE THE BIKE MUCH MORE COMFORTABLE TO RIDE
IN SUMMER HEAT.
* OIL/MOTOR RUNNING CONSIDERABLY COOLER WILL EXTEND SERVICE OF THE MOTOR AND ALL COMPONENTS WITHIN THE MOTOR LIKE GASKETS/SEALS/RUBBING BLOCKS ON TENSIONERS ON THE CAM CHAIN & PRIM CHAIN ,ETC.
But keep in mind i installed 2 cooling system mods (twin cooling fans & oil cooler with twin cooling fans too) both at the same to get those great results and to not expect the same results (50deg f redcution in oil temp) i got in summer heat if you dont install both the same type cooling system mods at the same time like i did omn my 09 Ultra for a max cooling effort which is by far the best money i have spent for anything on my HD to date because of all the benefits i got from it right off the bat after doing it.
Happy Motoring!
Scott
OldPhat
Jul 15, 2023 11:16 AM
kpb46
Touring Parts
Jul 13, 2014 03:56 PM
car5car
Oil Archive (no new posts)
Dec 27, 2009 10:58 PM
nmfxstc
Jun 18, 2008 10:21 AM
redhwk44
Jul 25, 2006 02:40 PM
