Adj backrest install
Old Jun 27, 2007 | 02:33 PM
mwriggs's Avatar
mwriggs
Default Adj backrest install
My daughter, along with my wife, bought me an adjustable backrest for our EG Classic for Fathers Day. I was wondering about how long should I expect to take installing it, and are there any quirks, or tips that some of you can offer and or explain?? I usually install my own goodies, and am mechanically inclined.....
Old Jun 27, 2007 | 02:40 PM
JW's Avatar
JW
Default RE: Adj backrest install
might take an hour or so, not to install but to install and uninstall to adjust to where you are comfortable. Some folks have even had to bend the backrest bars to get em comfy.
Kahuna's Avatar
Kahuna
I would say it will take about an hour to install. Some areas of challenge could be the routing of the cable and mounting the adjustment handle. Make sure you engine is cool, as you'll be working near the rear exhaust pipe. You'll need to remove your seat of course. Good luck!
ORIGINAL: mwriggs
Old Jun 27, 2007 | 02:45 PM
DrLove907's Avatar
DrLove907
Easy install, half decent instructions included. Like JW stated there may be some adjusting involved a little later.
Old Jun 27, 2007 | 02:48 PM
FLHT's Avatar
FLHT
About an hour is right, a couple of the bolts for the adjustmet lever are a little tricky to get in. I was thinking of bending my support also after I put mine on but I'm really getting used to the feel. It is great on the back.
Old Jun 27, 2007 | 03:17 PM
mrsr71's Avatar
mrsr71
For best results, run the cable a straight as you can. No sharp bends
Old Jun 27, 2007 | 03:25 PM
RDM's Avatar
RDM
I've been looking at one of these for my SG. Can you tell me where the adjustment handle is placed?
Old Jun 27, 2007 | 03:29 PM
mrsr71's Avatar
mrsr71
ORIGINAL: RDM
In front of the left side cover on the frame.
mrsr71's Avatar
mrsr71
ORIGINAL: RDM
Old Jun 27, 2007 | 03:33 PM
mwriggs's Avatar
mwriggs
Thanks guys!!
