EXHAUSTING QUESTION
Old Jun 28, 2007 | 11:07 AM
Corndog's Avatar
Corndog
Default EXHAUSTING QUESTION
I like the throaty sound, performanceand volume level ofthe Rinehart True Duals on my 07 RKC, but I am one of the unlucky ones to get the dreaded high-pitched chirp which is driving me crazy. What other brand of duals will be comparable to the Rineharts in sound, performance and loudness? Would V&H Big Shots be about the same? Thanks for your help.
Old Jun 28, 2007 | 12:40 PM
IceHeritage's Avatar
IceHeritage
Default RE: EXHAUSTING QUESTION
Thunderheaders
Old Jun 28, 2007 | 12:47 PM
cabbage's Avatar
cabbage
i just got the tru duals RH's as well...and after a couple hundred miles....i am starting to hear the high pitched chirp! wtf is that...anyway to stop the chirp?? not a fan at all. i never read of this chirp before i purchased the high digit RH's.
Old Jun 28, 2007 | 01:16 PM
cabbage's Avatar
cabbage
BTT! more info on this RH chirping BS and is their a cure for this dreaded condition???????? i thought there was a hole or a leak somewhere in the exhaust but no....then i see this thread mentioning the frickin chirp. never heard of the fricken chirp...didnt have it...till yesterday!
Old Jun 28, 2007 | 01:21 PM
smknflms's Avatar
smknflms
..do a search..lot's of fixes..mainly removing baffle and bending slightly.
Later
Old Jun 28, 2007 | 01:37 PM
cabbage's Avatar
cabbage
cool. ill look...in meantime just took a little ride and it doesnt chirp too badly, mostly at idle.
Old Jun 28, 2007 | 01:42 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Wear earplugs and/or listen to an iPOD. Harley says it's normal.j/k
Old Jun 28, 2007 | 01:49 PM
nightglide's Avatar
nightglide
go with the Thunder cones
Old Jun 28, 2007 | 02:29 PM
FLHT's Avatar
FLHT
ORIGINAL: cabbage
Try shooting a little WD40 on you rear rubber mounts. Those can start to make some noise when they dry up
Old Jun 28, 2007 | 06:27 PM
T.P.'s Avatar
T.P.
2nd Gear
RH isover priced junk? I even see you guy posting "listen ro a ipod so you will not hear it" wtf spending 800 bucks on exhaust that robs torque on anything less than a 95inch motor and sounds like a flock of chi-chi birds is less than wise in my humble oppion. But oppions very.
