Extended Controls Question
Old Sep 27, 2018 | 09:38 AM
allthefineprint@gmail.com's Avatar
Default Extended Controls Question
Shopping for everything I need to install my apes - aside from the obvious, how critical (or how much should I spend) are controls? I’ve seen control sets, clutch throttle and brake lines in the couple hundred range all the way up to over 400 bucks. I’ve got carlini apes and I’m tempted to just dish out the cash for carlini controls - but wanted to check with this group first.
What did you use and how much did you pay?
Old Sep 27, 2018 | 11:18 AM
Cygnusx51's Avatar
Cygnusx51
Price can depend on the length you need. When I needed longer cables, I measured the length necessary and had them made by Magnum Shielding. Yes it does matter as you want quality components.
Old Sep 29, 2018 | 04:15 PM
I guess I should’ve called this thread “16 or 18 apes” would’ve gotten 10k views and 100 responses.
Old Sep 29, 2018 | 04:43 PM
Solospec's Avatar
Solospec
I went with the magnum kit which was about 200 bucks when I installed my 14 inch wild one bars. I used the OE style black kit that only replaces the brake line to the ABS unit. I was happy with the kit. Does your bike have throttle by wire?
Phil
skinman13
Aug 3, 2014 03:28 PM
thelawnmowerman
Sep 24, 2012 04:10 PM
dcwilli1024
Sep 19, 2012 06:02 PM
ebeattie
May 31, 2008 10:13 PM
XL Junkie
Dec 1, 2007 02:35 PM
